How fast is a stock 89 TTA (really)???
Car: 87 Monte Carlo ss
Engine: ZZ4 1.5 rollers 650DP
Transmission: Probuilt 700-R4
Axle/Gears: 8.5 GN 3.42
There were a lot of things the montes didn't get that the 442s and Gn's got like the 8.5(which I have now)
but I really wanted a GN but I just kept looking at the monte and thought that it look kind of like a third gen and I like third gens.Must be that front nose.I just like the looks of the monte better.It is sad, the last full framed two door carbed car that GM made was so underpowered from the factory.They should have got the L98.
but I really wanted a GN but I just kept looking at the monte and thought that it look kind of like a third gen and I like third gens.Must be that front nose.I just like the looks of the monte better.It is sad, the last full framed two door carbed car that GM made was so underpowered from the factory.They should have got the L98. Member
Car: 91 Z28 24th Anniversary
Axle/Gears: Posi 3.23
Are you saying the 89 TTA has a different 5.7 motor than an 89 TA? Or a differnent motor than a 91 TA or a Z28, for that matter, which in 91 the HP rating increased? TTA stands for Turbo?
Unless I am mistaken TTA means (turbo trans am).They are 3.8 turbo v6.Like the grand nationals.TA Trans am is L98 350 V8.Same as 350 iroc or z28.Is this what you are talking about?The TTA's are very rare.
I edited my post at the same time. Saw another post about an 89 turbo and change it. What was the last year of the turbo?
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
Originally Posted by TTA 1387
Actually, the 83 and 84 Monte SS was quicker than the Turbo Regal. The Buick and Hurst Olds were about the same in performance. The Buick came to life in 86 with the intercooler and new placement of the turbo. A gain of 30/30+ will do that over the Olds and Chevy's 180/240 rating
i used to own an 85' GN. even though it wasnt intercooled it was very fun to tweak. and of course the turbo whistle/sneeze was sooo addicting! wish i never sold it
Originally Posted by tpivette89
maybe in 83' when the turbo regals were still carbed, but in 84' (and 85') they came injected. ratings were 200hp/300tq. best stock run ive heard of was high 14s. most were mid - low 15 sec cars though
, we had an 84 SS. My buddy traded is 84 SS for a 84 GN. That car was a beaut, even with LS seats. But it couldn't beat the SS. From a stop, roll, anywhere, except after 100mph. With only 3 gears in the Monte, it was starting to wheeze. Neither of us took either car to the track to verify any numbers though.He eventually traded that GN for an 86 GN. The Monte never could do anything with that.
Originally Posted by TPI-Formula350-
I'd tyake the TTA over the cobra in a sec. Whats the Cobra .2 faster and thats comparing a Supercharged V8 to a turbo V6
Good drivers can get mid 12s out of an 03 cobra. Free mods yield low 12s.. They also weigh a good 400 lbs heavier curb than a TTA. They are faster but the TTA is always going to be a rarer car. If you want flat out speed, the 03 Cobra is easier and simpler solution. I'd say the better comparison for the TTA is a 4th gen Supra. Same territory stock, same response to modifications, same killer top end, same indestructible rotating assembly, cept a TTA can actually hook hard
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
ofcourse both can handle mods well and respond well to minor changes..mainly uping the boost...
but i think the supra's motor/drivetrain is a hell of alot stronger than TTA's. i know supras have pushed well into the 800whp range on stock internals and i have heard as high as 1000hp. not sure if GNs and TTA internals can support that or not. but i know that 9 bolt and stock 200r4 wont hold that LOL
i agree with you that the TTA might hook harder than supras, but same response to mods and indestructable rotating assembly might be alittle off.
TTA's can easily be made to run low 11's on pump gas/alky. I did it in mine. Heck there is a guy trying to run 9's on pump gas in his TTA. Might have already done it, have to check. Pretty stout if you ask me
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
If your refering to Julio, he's still in the mid 10's @ 130-132, but that is on drag radials no less.
Originally Posted by 1BADDAM
Rob,
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
13.3-13.4
Best mph was 103.---
96k bone stock virgin.
On street tires
Only time I ran it stock
Brake and get about 2psi boost and let it fly.
later
Jeremy
On street tires
later
Jeremy
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: How fast is a stock 89 TTA (really)???
I have seen times from 13.3 to 14.0 with the TTA driven properly dead stock. Keep in mind that the faster of the breed could keep up with the GNX and could touch 160mph under the right conditions. I guess they were pushing 270 to 280hp with a 200lb weight reduction compared to the GNs.
Now I'm not going to pick on the Cobras - they are fast stock and very fast when moded, but a low buck moded TTA is going to run just as fast as those cars - turbos have a lot more upside than superchargers.
I hope a forged straight 6 can hold more power than a V6 - but a fully worked over GN based motor is going to easily match the Toyota's in power, plus have more low end due to having more displacement. I laugh at the 1,000hp+ Supras and several seconds of lag until the big turbos kick in and everything goes by in fast forward.
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
Car: 1999 Trans Am Ram Air
So a bone stock L98 putting 215whp? Maybe with a T56 swap, but not with a auto. L98s dyno right around 180whp IIRC.
As for the TTAs. Mid-high 13s seems about right. The best comparison would be an LS1 F-Body and with just a couple dozen more ponies, they can manage to net them a low 13 with a good driver and a 6 speed.
Again, this is on average. We all know there are factory freaks out there. Like some of the LS cars making close to 330whp bone stock. But please don't put blatantly false information.
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Back in the late 80s i worked for Conley'sPerformance Plus and if you are familiar with the name you also know we did TONs of GNs, along with syclones,typhoons vettes and a few mustangs.
We had a few TTA owners and they had no problems running 13.3s at sea level with that said traction was VERY good at HOUSTON RACEWAY PARK which is now Royal Purple Speedway.
I had thepleasure in making many passes with customer cars aswell as my own. On average the best races were the syclone and TTA heads up in stock form , the best run EVER was a TTA running 13.1 at 108 and the syclone 13.3 at 105. I truly miss those days with AMERICAN TURBO engineering. These cars were a decade ahead of any other AMERICAN car!
you did less mods to get your TTA in the low 12's then i did to get my L98 into the mid 13's...
Here's a new question for this post. What car will be worth more 10 years from now, in the same condition and mileage? There were alot more than 1500 03-04 Cobras made.. i bet a TTA in primo condition will get 35 grand...
Car: 1991 Z28
Engine: 5.7 TPI L98
Transmission: 700-R4
Axle/Gears: Moser 9" with 4.11
Fast355
Dec 2, 2016 06:33 PM
Genopsyde
Oct 7, 2015 08:35 PM
