Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
355 sbc
Old Jul 14, 2006 | 02:54 AM
85T/A's Avatar
Car: 85 Pontiac Trans Am
Engine: wouldnt you lilke to know??
Transmission: TH350 Built to the hilt
Axle/Gears: 4:10 Gears Moser Axle Auburn Posi
355 sbc
not sure where to post this figured here would be best so if i m wrong plz redirect me ....I have an 85 TA.. Obviously ... its got a 123,000 mile tired LG4 305 i was wondering weather anybody could tell me what i would run now with a small cam, intake , 600 edlebrock carb 4brr, k&n 14 in" filter and that one thats a filter / lid also by k&n, weind dual plane midrange intake nothing running off the crank xcept power steering alternater and water pump and a freed up exhaust system... no cat and an 80 series flowmaster which is nothing but a sideways 40....
thats my first question now my second i m building a 355 sbc with 11:1 comp full roller valvetrain , 502/502 (with 1.5 rockers i m using 1.6 thinkin about 1.65 still have to do the math)roller cam from lunati summit brand cast iron heads preassembled built to take a 550 lift cam.. edlebrock 2701 performer eps intake and an edlebrock 750 4brl carb ....the heads have 1.9 intake and a 1.6 exhaust i m going to be using headman long tube headers
can anybody tell me what they think that motor will allow me to run and what kinda specs should i expect???????
Old Jul 14, 2006 | 06:28 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Do you have headers? What cam? What gears? Posi? Stock heads?
What duration is the cam and what LSA? What rear end gears/posi? Weight?
Old Jul 14, 2006 | 09:07 PM
85T/A's Avatar
now stock heads.... 398/420 lift i forget the duration i do not have headers i have 3:08 and by the way my rear acts i believe i have an open rear
355
cams duration is sumtin like 272... not sure what lsa is....posi rear 3:73
origianl wieght puilled things like ac and smog pump....
and the heads they have a 202 intake sry not 1.9
Old Jul 14, 2006 | 10:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What heads (not just valve size ). Are they aftermarket or stockers? My guess is that cam would be around 220 or so duration. Your combo should be a solid 350hp and your current LG4 should be capable of running low 15's/high 14's.
Old Jul 14, 2006 | 10:36 PM
85T/A's Avatar
their summit brand cast iron .... i am assuming that thier ported and polished
if not then i have to do it myself at school when i order them
and are low 15 high 14 s good for an lg4???
Old Jul 15, 2006 | 10:28 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They won't be but porting will be worth it.
Yup.
Old Jul 15, 2006 | 10:56 AM
r0nin89's Avatar
Car: 1987 Chevy Stepside
Engine: 350 TBI w/ a Cam
Transmission: 3 Speed Stick w/ granny low
Speaking of 305's shifty what does your 300hp LO3 run 1/4 mile?
Old Jul 15, 2006 | 09:16 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I should have some new track times by this fall. I should have more than 300 hp as well (fingers crossed). Stay tuned.
Old Jul 15, 2006 | 09:35 PM
Car: '72 Chevy Nova
Transmission: TH350
damn shifty I've been waiting to see track times from your hot rod forever
As to the original poster, probably low-mid 15s with the LG4. and i agree with shifty probably somewhere around 350 hp at the fly with the 355, which will probably take you to a low-mid 13 on a street tires depending on how well you drive.
Old Jul 16, 2006 | 08:41 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You and me both!
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
