350 SBC vs lt1?
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
350 SBC vs lt1?
I have a buddy around here with a 94 z28 that has an lt1 slightly modded in it, hes been asking for a race but im to afraid to lose so i keep stalling, so i thought id ask yous who might win.
I have an 84 z28, built 350 with speed pro everything, lifters, rods, pistons, etc, its bored .30 over and i have the headers, catback all that small essential stuff done already, 750 holley double pumper, HEI distributor and coil, etc... Its never been on a dyno yet but just takeing a wild guess with the info provided, who might win givin the drivers are both to the same ability.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
There is no way to tell what kind of power you have without knowing the intake design, cam specs, heads, and compression ratio.
By the way your B&M shifter has the long shifter handle for a truck not the short one that comes for thirdgens. I have a brand new short handle still in package if your interested.
Car: 84' z28
Ill have to dig up the specs on the cam and heads here shortly.
As for the shifter, i want it that way, i dont like the short ones "for 3rd gens" even though their only about half an inch shorter...
Car: 87 IROC
Did you have one on your car already? Because I had the long on mine and the shorter one felt better the long one just felt weird.
Car: 84' z28
Yea, i had the short one on, i bought the kit i still have it laying around here somewhere.. i have longer then normal arms i guess, it felt like i had to reach for it, the longer one just sits right where my arm would be positioned normaly, i like it
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
I've seen some pretty lazy LT1's.
Unless your running stock, what the h*ll is there to be afraid of?!
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
LT1s aren't that special, if you have decent heads and a halfway decent aftermarket cam w/ the supporting mods like headers/catback, etc you can take one. They only make around 250 rwhp stock, or around 300 hp at the crank. Other than the reverse flow cooling and a decent factory EFI setup they're just a SBC anyway. Heads are decent but nothing special stock, stock cam is fairly mild. You can easily match or beat the LT1s power output w/ an average decently setup carbed 350 w/ mild supporting mods.
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Mickeyruder
Sep 2, 2015 02:45 PM
Eric-86sc
Aug 24, 2015 09:01 PM
