0-60
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
0-60
So I realised today that I have a stopwatch on my phone.
0-60 in 6.22 seconds.
Should I be expecting this with my engine combo? Or should I be expecting less?
I have a crap load of stuff in my car and I had a half tank of fuel. I know if my car was empty I would easily break the 6 second barrier.
So 6.22 seconds, is that pretty quick?
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
Well with that whimpy cam and carb you got I'd say your right on where you should be. Do yourself a favor buy a DP carb, airgap intake and a nice cam/springs set! That will change everything.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I agree. However, 6.22 (that has some tollerance since there is stacked error between your speedo and the quickness of you running the clock) isn't all that bad (for a combo that is driven every day with a full weight car) and could really be anywhere from 5.8 to 6.5.
Car: 1985 IROC
Axle/Gears: no idea
All in due time, im running on a shoe shiners budget. =\
Yeah, some reason last night my car was launching HARD when I nailed it. I was driving it for over an hour though before I started ******* on it.
theformula
Aftermarket Product Review
Nov 15, 2000 10:23 PM
