91 Z28 vs 96 Impala SS
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
My 91 Z28
305 TPI
5 speed trans
SLP cat back
some drivetrain mods
runs mid 14s in the 1/4
VS
96 Impala SS
some bolt-ons
K&N intake?
exhaust?
I think it will be a good race. I'll find out next week.
305 TPI
5 speed trans
SLP cat back
VS
96 Impala SS
some bolt-ons
K&N intake?
exhaust?
Car: 1989 TRANS AM GTA
Engine: 355 L98
Transmission: Built 700r4
Axle/Gears: BW 3.27
When you say some bolt-ons does that mean the exhaust and k/n or those plus more?if that is all he has you will win with no problem at all if you run mid to low 14"s he will only get low 15"s with just exhaust and filter
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
Not necessarily. I owned a '96 Impala SS from '98-'00. All I had done to it was a K&N cold-air setup and Flowmaster dual catback, and it ran consistent 14.7s, with a best of 14.63. Would be a good race for sure!
Car: 91 Z28
Engine: 355
I think it just has a k&n intake and a cat back exhaust. My cars run 14.5 in the 1/4. Only mods I've done since then was went from 3.42 gears to 3.73s, and swaped the steel drive shaft for a aluminum one.
Car: 1984 Firebird T/A
Engine: 406sbc
Transmission: TH400
Axle/Gears: Moser 9"
Re: 91 Z28 vs 96 Impala SS
Should be a prett close race depending on what he has done to the Impy. My dad has a Caprice 9c1,with a hypertech chip, stock exhaust 3.73 gears and a higher stall and he ran 13.9.
Car: 89 formula, 89 Cadillac Brougham
Engine: 355,HSR,patriot alum. heads,TFS cam
Transmission: 700r4, 2500 B&M stall, shift kit
Axle/Gears: 3.73 ten bolt, powertrax locker
my stock 96 roadmaster wagon has gone 15.2 in the 1/4. i'm sure that my car has a few lb's on the ss. it'll be close.
Car: 1983 G20 Chevy
Transmission: 4L60
Don't under estimate the Cast Iron head LT1 engine (Vortec is very similar)
a quick google search says my wagon's curb weight is 4,275lbs. it's also slightly more aero. than your van.
Car: 1983 G20 Chevy
Transmission: 4L60
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
blackz281le
Jan 11, 2016 07:51 AM
