Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
385 hsr vs 05 srt 4
Old Jul 10, 2007 | 03:08 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
385 hsr vs 05 srt 4
Alright my mods are in sig...race will happen after the tranny swap and better gears...... He is stage 2 plus (this is what gets me angry) he is spraying.....130 shot. Ill have torque arm and hopefully MT drag radials also...... MY dyno is in sig but isnt complete b/c tranny is FUBAR but i saw his dyno...said 390. I think i will lose but what do you guys think?
Old Jul 10, 2007 | 03:39 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: 385 hsr vs 05 srt 4
Is 390 hp w/ the spray?
Old Jul 10, 2007 | 04:55 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
390 hp in a light neon will beat 338 hp in a heavy 'bird.
If that 390 hp is before nitrous, you're screwed. If it's after nitrous, then tell him to leave it off the car, or add a little giggle gas to your car.
Old Jul 10, 2007 | 05:55 PM
sach712003's Avatar
Thats a lot of horsepower for a front wheel drive car. Also the tires on those things are only 215 series so they are not very wide. There is no way he will be able to put that kind of power to the ground from a dead stop he will just smoke his tires or his clutch. Plus those cars have a real low first gear which will not help him. It will also depend on how good of a driver he is. Race from a stop and if it is a short race you could probably win. If it is a long race you will probably take him from the line but he will catch you in the end even if he is a crappy driver.
Old Jul 10, 2007 | 09:52 PM
Car: 92 Camaro
Axle/Gears: S60 373
390 is with the spray. and the 338 like my signature says is with a badly slipping transmission (revs up about 700 rpms before shifting), a non lockup converter and the stock 9 bolt rear end. In other words Wgripp do you think any of those three are holding back any power left in the car?
Old Jul 10, 2007 | 10:40 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
390 in a light car is going to be hard to beat.
Hope that he has a 'tard moment and botches the launch or hope he spits out a half shaft when launches
Old Jul 10, 2007 | 10:56 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
if he doesn't spray u, u might have a good chance of beating him. if he sprays u, ur toast
Old Jul 11, 2007 | 05:47 AM
Car: 92 Camaro
Axle/Gears: S60 373
without spray he is at 280-290 to the wheels...thats almost a 50 hp difference between me and him....then again he is about 400-500 pounds lighter....
Old Jul 11, 2007 | 11:53 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
just hook up real good. and let us know what happens.
Old Jul 11, 2007 | 12:20 PM
kazer's Avatar
an 05 srt has a limited slip, but they still don't have traction (at my last autocross I actually outran a modded srt-4 with my stock 92 RS). But, if he has slicks, he will have enough traction to beat you. There is still the possibility of him missing a gear, etc. 500lbs of weight loss is generally 5/10 of a sec in a quarter, right? (i think thats right). I think your traction could make up for that, especially of your old tranny really hurt your dyno.
Old Jul 11, 2007 | 01:07 PM
Car: 92 Camaro
Axle/Gears: S60 373
im hoping that slipping tranny sucked up 20-30 ponies bc getting a rebuild in ab a week or so
RedLeader289
May 28, 2019 01:47 PM
86z89iroc
Oct 5, 2015 01:04 PM
mike22115
Sep 28, 2015 04:49 AM
RedLeader289
Sep 23, 2015 06:50 AM
BBSDesigns
Sep 22, 2015 03:08 PM
