another vid of my 305 tbi w/ spray
Guest
Posts: n/a
since my last thread got CRAPPED ON by a bunch of certain individuals who felt it VERY necessary to stuff their opinion down my throat and got the thread locked, i will post the video here.
http://youtube.com/watch?v=KfbJFGcx0SY
some of the info in the vid is wrong, my car is a 92, and i didnt make the vid so dont tell me i spelled passenger wrong.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: another vid of my 305 tbi w/ spray
Cool, Nice kill on the lightning. I also noticed that the race against the Z28, his honking sucked. His last honk was too fast. But he got you. So what are you running in the 1/4 mile?
Guest
Posts: n/a
thanks. and yea i just noticed he did do a cheap shot with the honk. i stayed about 2 cars behind him until we passed the finish (you can see the cars nose and some people standing there) where i let off and he STAYS going fast.
as far as 1/4th mile times , 16.3@101mph.
i outran a 13flat mustang not too long ago tho... heh.
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
um, do you mean 14.3? hell even 13.3?
101mph is insanely fast for a 16 second car.
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
yeah stuff isnt adding up here. My 90 305 tbi went 15.7 at 88mph, so how is it you managed to go "slower" and yet go "faster" at the same time....hmmm....unless you made an honest misprint mistake I am calling bs. Put on your waders boys, shnits getting deep.
Car: 83 Trans Am
Engine: LT1 350
Guest
Posts: n/a
i have a video of my 16.3@101 mph run. haha..
i posted above clearly stating i outran a 13flat mustang did i not?
this is my car when it ran the 16.3@101, i cut a 2.8 sixty foot and i let off when the smoke stops then got back on it, but it was too late. uhm, the best run i managed that day on the 100 shot was a 14.3 @ 100mph with a 2.6 sixty foot.
but like i said, 150 shot + better tires, and some stuff removed from the car, i outran a 13 flat mustang, 05 GT with some mods.
Im gonna guess you didn't see my other thread.
go lurk more. read more, then start callin BS on stuff you can actually back up. if you dont know how someone could run slower with a higher trap you need to seriously read up on what happens under various situations on a 1/4th mile pass.
Transmission: a
hey calm down, I was just askin.
you may want to go into some suspension work next, it'd really wake up your trap times.
Car: 83 Trans Am
Engine: LT1 350
open mouth; insert foot.....do we have a smiley for that here?
ha man, just call it as I see it, sometimes people are wrong, and this time its me. **** happens...
Not bad for a 305
Not bad for a 305
Guest
Posts: n/a
sorry man just really tired of people crapping on other peopels stuff. its what got my last thread closed. i ahd a massive 2 length long post detailing a lot of stuff aboutm y car and quite a few videos. guys got butt hurt and i tried to defend myself and it got locked.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Just as a purely objective thought, have you had any thoughts of doing a build-up on the 305? For about the same as the nitrous, you can get a set of heads and an old flat tappet cam kit and get about the same level of performance that your getting with the power adder. A comp-cams cam kit (something like the 262-112 LSA) and a worked over set of LB9 heads wouldnt cost too much and would be good for 13's. For even more fun, build the 305 up AND run nitrous.
cool vid, nice race against the LS1. Although both the T88 355ci, and the built 305 tbi sound like great unique builds, I would like to see what a built 305 tbi can do with some nitrous. You really don't see those types of builds very often.
very decent car tho..
Guest
Posts: n/a
you let me worry about that. I will bet you 500 bucks i spray a 200 shot with a t88 on my way to work when i get it mocked up on the 305.
500 bucks. we can set up pay pal accounts and i will get video. if it blows, ill give you 500 bucks. if it makes it, you have to pay pal me.
stock bottom end. 166k mile 305 tbi.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I don't know if you annoy me or if you entertain me, maybe it's both.... Last edited by Raiderfan; Aug 7, 2007 at 04:23 PM.
i can see that you are serious. I have a doubt as to that setup lasting a while but that doesn't mean I am right. It would be interesting none the less to see, and you should do it. But just for your own enjoyment.
I think that a boosted and sprayed 305 TBI would be plenty of power, don't you think? Wait, can't you fit your fist inside of a T88?
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
First off this is dangerous in so many ways it scares me. Second off bragging about building something like this and blowing it up (which it will if not the first time you hit it, one of the next few) just reinforces some things. I sure hope the motor you are building for the T88 isn't a stock block junk motor your going to put it on to begin with.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
I can see why your last thread was "crapped on".
I'll just leave it at that.
Guest
Posts: n/a
so you just HAD to post here huh? Ill just leave it at that.
who said the t88 would be supplying any boost to the engine? Im just here to make a quick buck.
and yes i think you can fit your fist in side the t88. i think ive swettled on another turbo though. PT71gtq. its basically just as big. but a much newer turbo.
oh its a stock block, little bit of block fill, up to the water pump outlets. probably vortec heads - dunno what else to do on a budget i guess, vic jr intake, probably gonna have the 2 bolt converted to the splayed 4 bolt setup. and a forged crank, eagle H beams, and je pistons. only things i can afford. and why the **** do you guys care if i blow the engine. are you relying on it to take you to work in the morning? nope. o well ok then.
Car: 83 Trans Am
Engine: LT1 350
ha man the hell with the hecklers, its your car, mod the hell out of it, do what YOU want, have fun with it, and if a day comes when you have that nagging thought in the back of your mind to blow that b**ch sky high, then for god sakes blow it. Who cares what other people think. I have nothing against the 305, its a good motor and though its not the "peoples choice", its not the "peoples" car, so have lots of fun with it, and dont stress over the hecklers, they seem to be everyone around here, they are like muslim extremists, just cant mind their own damn business and gotta trash talk, and attack everyone else cause they have nothing positive to offer.
I suppose some of your disgust is with me. I'm just tired of reading posts by guys who have no concern for anyone but themselves. What you're doing with your car may be fun for you and we all appreciate you posting results for us ALL to learn from. Just don't get yourself or anyone else hurt or killed. Why does everyone have to be so "extreme" these days?
Car: Mustang
Engine: Bolt Ons
Transmission: Stock
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
As a huge supporter of tormenting the 305 to test how much you can wring out of it and how long it will last I also see what they're saying here. I think you should just play it equal and make sure you let it be known this is a personal experiment and that you are taking a risk, not trying to make an example.
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
thats pretty kool, for only a 150 shot that baby will move.
also I could beleive it holding to a 200 shot with over 100k on the clock especially after witnessing sbc durability. I think our biggest help is probably that the valves start to float so early on most of the 305s that it makes it hard to over rev realy. AS fof high cylinder pressure it'll old for a while im sure, sooner or later it will blow but, hey nothing is permenant especially in the aftermarket modified car industry, everything is give and take.
plus i had a 1992 camaro and i know exactly what you mean with a 2.8 60 footer. best i got outa mine was a 2.62 but, it was a dying 305 (low on compression).
2.73s + oogles of power just = flames imo from my lowly driving experiences lol.
anyways i cant even launch a posi 255/60 5 spd speed iroc. best launch i had all night yesterday was a 2.34 60 footer lol , then again the tires are dead and missing chunks maybe thats why, or maybe i just suck that bad but, either way props to an interesting video and build up.
92camaroJoe
Aug 13, 2015 06:07 AM
