Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
00 SS SLP vs 383 gta
Old May 24, 2008 | 07:49 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
OK I just got my car back on the road and my friend is claiming that his 00 SS SLP edition can beat my 91 gta. his car is factory stock besides a cat-back exhuast. We both are running 6 speeds. My motor is as follows 2 bolt main 383 stroker, 10.3 to 1 CR with trickflow 23* heads, comp cam 230/236 duration; 570/576 lift, 1.6rr, hsr intake (home ported), 30lb SVO, AFPR (set at 32psi), msd wires/6al/coil, smog detele, 58mm tb, 3.73 gears, hooker shorty headers, 2.5" y-pipe, 3" flowmaster cat-back. I don't have any suspension mods yet but I still think I can beat him because I raced him before it went down last time and we were pretty even but my car had some problems so she wasn't running her best. I read that most 383's on here run mid to low 12's and a stock ls1 should run a mid to low 13's with a good driver. Shouldn't I be able to walk him pretty easy?
Old May 24, 2008 | 08:19 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: 00 SS SLP vs 383 gta
Id say u walk all over him because 3 gens are about 400 lbs lighter from what ive read. If you have it tuned right id say u win and if you have a good reaction time the go for it. Ive kept up with an 01 LS1 from about 40-WOT. he finally passed me about 80 ish and he was supprised how fast my car was for just a small 305.
Old May 25, 2008 | 12:17 PM
1BadaGTA's Avatar
Yeah that what I thought but we mostly go from digs and I just put in new shocks which I NEEDED BADLY. I just got done test driving it with a couple of friends and its a night vs day difference of how well it lanuches now.
Old May 25, 2008 | 04:13 PM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
i say take ur car to the tracks first and get used to launchin the car.
Old May 29, 2008 | 01:13 PM
myTreadZz's Avatar
if you can drive, you'll be able to take him. Go from a dig, and as others are saying: learn to launch well
Old May 29, 2008 | 10:07 PM
slohand's Avatar
Car: 91 z-28 conv.
Engine: 350 vortec tpi crate
Maybe it's me but I'm trying to figure out without a major screw up how you can loose? If it's a little stop light action or even the 1320 you shouldn't have a problem. Heck all I have is the lil' ol' vortec crate and few other items and from 0-70 or 80 stop light runs have out run several ls-1s including the SS camaro.
Like I said maybe it's me but you should have this going away.
Old May 29, 2008 | 11:06 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
I say get some either Et streets or the mt drag radials LCA and LCARBS and go LS1 hunting
edit saw you were a 6 spd, i heard manuals have a hard time with the ET streets
Last edited by 89formula350b2l; May 29, 2008 at 11:07 PM. Reason: Automerged Doublepost
Old Jun 1, 2008 | 02:46 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Unless you miss a shift there's no reason you should lose.
Old Jun 3, 2008 | 12:46 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
thats a huge lift on that cam.....
Is that at .050 duration?? wtff
what size heads you hve? Im lookin for 11's on my setup
Old Jun 3, 2008 | 12:55 AM
PHAT89TA's Avatar
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
what u dyno with ur 383?
Old Jun 3, 2008 | 02:57 AM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
looks like hes got the XFI grind... the lift is at 0.50, but thats with 1.6 rockers
FWIW, those shorty headers and dinky 2.5" ypipe are going to hold you back, especially on a 383. start saving for some long tubes
TX-SleeperC5
Feb 24, 2016 01:34 PM
2MNYMaros
Sep 15, 2015 11:36 PM
timonator
Sep 11, 2015 05:11 PM
buckshot63
Sep 10, 2015 09:15 AM
