Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Just kinda curious
Old Jun 24, 2008 | 12:41 AM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
Just kinda curious
So my car is a work in the process but a buddy of mine already wants to race when its done. Would love some feedback/suggestions(lets avoid the "you need a 305/350/etc" ). The list below are planned mods.
'92 bird. 3.1L. 10-bolt, 3.42 posi. Kuhmo Tires. 700r4 w/ shift kit. decently low miles.
ported intake/heads.
aftermarket cam.
Headers.
Custom CAI.
Good flowing exaust.
vs.
Bone stock(other than crappy body kit) '96 Eclipse turbo, 5-speed. 180+k miles.
approx. 5lbs of boost.
Guy doesnt seem to understand WTF a spooled launch is.
Average run-of-the-mill street tires.
What do we think?
Old Jun 24, 2008 | 06:01 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Just kinda curious
aftermarket cam.
Good flowing exaust
all three are quite vague, many different ways they could go, it would be hard to give a real idea without some specs
Old Jun 24, 2008 | 06:56 PM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
I havent quite firgured out what I wanna do with heads & intake just yet. As for the cam, probably go with the .454 lift cam that I found. For exhaust, Im thinking no converter, 3" pipe into a Cherry Bomb Vortex, dumping into dual 2 1/4 or 2 1/2" pipes. I also considered some forged pistons.
Old Jun 24, 2008 | 07:05 PM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
What do we think about adding a Double-Roller timing chain & 1.6:1 comp cams rockers? Just trying to get this all settled and figured out before I start to buy parts and put the motor back together. Definately up for suggestions. I'd like to make decently respectable hp for a v6. At a later date I will add a turbo but thats some time away.
Old Jun 24, 2008 | 07:57 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
The eclipse is it a gst or gsx? or just a gs turboed? 5spd? this might be a good race the boosted eclispes are fast but i think if you make about 250-300 rwhp you have the race unless its a gsx then he'll get you out of the line (if he can drive) dose he suffer from boost leaks? or crep?
Old Jun 25, 2008 | 01:14 AM
LMSkyliner's Avatar
Car: 1989 Iroc-Z
Engine: 383 FFI
he has a 3.1
sorry the eclipse should take this one easily. There arn't enough mods done to your 6 too keep up. As much as u want to avoid the typical cubic inches trolling, unless your boosted, there is no replacement for displacement.
Old Jun 25, 2008 | 01:32 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
You don't have the mods necessary to overcome the over 60 hp advantage the eclipse has over you. Plus if it probably weighs a couple hundred pounds less than you.
You either have to have forced induction to do this, or pour a great deal of work into that motor to do this. That means intake, heads, cam, injectors, full exhaust, a complete tune, and even then you may want to consider forced induction or nitrous.
Old Jun 25, 2008 | 02:01 AM
two60two's Avatar
Car: 07 Saab, 88 Turbocoupe, 85 XR4Ti
Engine: LP9, 2.3t, 2.3t
Transmission: 6 speed auto, t5, t5
Axle/Gears: ? , 3.55 8.8", 3.64 7.5"
I agree with you. 2g Eclipses come in varying forms. There is an RS, GS, GST, and GSX.
All of the turbo versions run 10 pounds stock. Why would he only push 5 pounds unless its a cheap turbo conversion?
Old Jun 25, 2008 | 10:28 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
V8 swap, then sleep easy at night.
Old Jun 25, 2008 | 11:02 PM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
The setup Im looking to do currently, my uncle did on his 3.1 and made something like 203 to the wheels. I've considered many things except nitrous. That will never go on my car. I'd rather live by all throttle, no bottle and get whooped than to spray. I would swap out for a 350 but I honestly just cant afford to build a decent small block right now. I see no sense in building a stock one.
His car is a gst. The only thing I know hes done to the car is switch to an external wastegate when he replaced his turbo w/ another factory one. I dont know why he runs 5lbs. personally i'd have to build that motor up and run 15+. There is nothing wrong with the car other than its just a little tired. Hes not the greatest driver but hes not terrible. He would be much quicker if he could be spooled on a launch.
Old Jun 25, 2008 | 11:17 PM
two60two's Avatar
It's front wheel drive and stock DSM blocks are good for a good amount of boost. The turbo is his limit on boost right now. He can safely and efficiently run that 15 right now. 17 psi is where is turbo is going to just blow hot air.
Either way he would still have you.
Old Jun 26, 2008 | 04:13 PM
V6Turbo's Avatar
Car: 1991 Caprise SS
Engine: 350 LT1
He can't spool on the line because he has a 5-sp manual. He needs to build rpm's and you need an auto to do this.
Old Jun 26, 2008 | 07:42 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
or if it was from a roll he could brake boost. The 7 bolt DSM motors really suck compared to the 6 bolt (found in 90-92) the 7s arent as reliable but still can handle alot of boost stock their also known to get crank walk and all that good stuff. i really cant belive at that many miles its still running
Old Jun 26, 2008 | 11:39 PM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
I was told today that a factory supercharger from a 3800 would fit my motor w/o any real problems. true or false?
yeah it runs. its a lil tired but it will still get up and go when it wants to.
Old Jun 30, 2008 | 10:15 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
correct me if i am wrong but 90* v6 parts don't interchange with 60* v6 parts
the 3.1 i know for a fact is a 60* v6 and i am almost sure the l67 i have in my buick is a 90* v6
Old Jun 30, 2008 | 11:56 PM
31BiRd92's Avatar
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
I personally have no idea. I was just told that it would and was just trying to check some facts.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
