Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
Guess my time
Old Jul 18, 2008 | 03:57 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Guess my time
Ok i am headed to the track tonight, just wanna see what you guys think it will do
383
10.7-1 CR
ported vortec heads
comp cam 272/292 .498/.510 @.500
crane full roller rockers
holley 830 DP
Rpm air gap intake
3500 stall
manual valve body
msd 6A, Dizzy, blaster 2 coil
36* timing
stock 2.23 rear, and susp.
I am also at 5000 ft above sea level. what do you guys think
Old Jul 18, 2008 | 04:08 PM
Pyroviking's Avatar
Re: Guess my time
low-mid 13's?
Unless your rear is really a 3.23, not a 2.23, then hi-12's/low-13's.
Old Jul 19, 2008 | 08:01 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Re: Guess my time
You have a 3.23 rear
What trans?
Old Jul 19, 2008 | 09:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Guess my time
5000 ft will kill the times, i have no idea what to expect
on sealevel or so, i'd expect mid 12's atleast, car could use more gear. Also depending on launch/weight etc
up there, i'm gonna guess lower 13's
Old Jul 21, 2008 | 06:34 PM
stroker86's Avatar
Car: 1986 Camaro Z28
Engine: 383 cu in
Transmission: 700R4 with upgrades
Axle/Gears: 3.23 posi
Re: Guess my time
the stall will help plenty... although not familiar with 5000ft above sea level.
with any kind of tires, 12.8-12.9 trapping 104-106
no tires, 13.2 about the same trap.
12 second car is pretty respectable
EDIT: assuming 3.23
Old Jul 21, 2008 | 09:45 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Guess my time
That cam is going to be a high winder - so you need to gear it higher...
The most important item you need to understand is tuning. Getting the timing, air/fuel ratio, exhaust, and traction right can turn a high 13 second car (which is what it will run at your altitude) into a low 12 second one.
midge54
Dec 27, 2019 04:14 PM
Cleotiz
Jan 6, 2018 08:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
