ls1 intake on tpi
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: ls1 intake on tpi
what design aspect are you looking to keep? there is no way to modify the intake to fit a gen1 engine. If you are just going for looks, thats kind of pointless, and the design of the ls1 intake and head ports are totally different than a gen 1, and thats where the flow advantages come from.
Car: 1989 GTA
Engine: 5.7 350
what your trying to do would cost more than its worth. If this were even remotely possible i think someone else would have tried it. Supreme Member
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
there are plenty of options if youre looking for more rpm out of a TPI motor:
1)miniram
2)stealthram
3)edelbrock proflo
4)superram
5)carb intake w elbow
6)siamesed TPI
of course, your stock heads and cam will limit the power you make at higher rpm since they were designed for the TPI system
1)miniram
2)stealthram
3)edelbrock proflo
4)superram
6)siamesed TPI
Car: 87 GTA
I'd rather see long tube, TPI style runners, on a LS1 bock, but the airflow style wouldn't match real well. Maybe higher rpm/different flowing LS1 heads?
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
ambainb
Apr 25, 2016 09:21 PM
Sanjay
Aug 12, 2015 03:41 PM
