Guess my hp/tq
Car: 89 TTA
Guess my hp/tq
I Just got my 1st custom 350 built and wana know what kinda numbers it may possibly make.Any input is greatly appreciated,anyways heres the set up.
Vortec 350 4 bolt main(stock bore)Balenced
stock 350 L98 crank
comp cam 268 XFI Roller
L98 Iron heads screw in studs slightly ported
Comp magnum 1.52 roller rockers
Comp High energy push rods
comp magnum roller lifters
comp double roller timing chain
Holley Stealth Ram
Tpis 58mm throttle body
24 lb Injectors
Harris stage 2 chip
flowtech headers and y pipe
borla cat back (no cats)
Ill post numbers this spring after a dyno run
stock 350 L98 crank
Holley Stealth Ram
24 lb Injectors
Harris stage 2 chip
Re: Guess my hp/tq
stock 350 L98 crank
comp double roller timing chaing
Holley Stealth Ram
24 lb Injectors
Harris stage 2 chip
stock 350 L98 crank
Holley Stealth Ram
24 lb Injectors
Harris stage 2 chip
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
Re: Guess my hp/tq
656 hp/ 585 trq..............................on a bad dyno
lol seriously I figure around 350-360hp and 360-380 trq
