me vs chevelle on NOS
From: Coulterville, IL...Currently on Beale AFB, CA
There is this guy that is the "king of the hill" at the local street races. He runs 13.0 or so on the motor but races with a 150shot of NOS. I have recently got new tires on the car (so now it hooks, and they are shorter so it helps the gear ratio). I know it will be close, but what do you guys think? My best time at the strip is below, keep in mind that it spun so hard when I hit second on this pass, I had to get out of it. Thanks Guys
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...12.72@ 116.9 with a 2.16 60ft time on BFG radial TA's
You are beat
Steve
88 Firebird TBI,TH700R4 - Open Element, Cat Delete, K&N filter 14*4 element, Flowmaster Catback Exhaust, 180 Stant thermostat, Accel cap and rotor
1/4: 16.1@85.7 (Bone Stock)
Steve
If I were u I'd invest in a set of ET streets and some suspension work. Your car mph is good, it should go mid 11s if u can hook and get a good 60ft. My buddys 70 Chevelle goes 11.60 @ 115 with a 1.65 60ft.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS
K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER
CRANK PULLEY, MSD, FUEL PRESS REG
COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR
BIG BLOCK, PUMP GAS
350TH w/ATI 10"
12-BOLT w/373 GEARS
10.90s ON MOTOR - ET-STREETs w/MUFFLERS
K&N, AIRFOIL
14.1@ 98MPH
OTHER RIDE
BIG BLOCK, PUMP GAS
350TH w/ATI 10"
12-BOLT w/373 GEARS
NOS leaves nothing for the imagination!
It's what use when there too stupid to build a real engine.
Ok now that thats said
The chevell will eat you up bad, if he's on the bottle. That crap is killer power although "cheap hp". off the line I would say you would be ahead untill he hits the swich. See if he will race you W/O NOS that would only be fair.
SSC
[This message has been edited by SUPER-SPORT-CHEVY (edited May 09, 2001).]
.The chevell will eat you up bad, if he's on the bottle. That crap is killer power although "cheap hp". off the line I would say you would be ahead untill he hits the swich. See if he will race you W/O NOS that would only be fair.
SSC
<font face="Verdana, Arial" size="2">Originally posted by SUPER-SPORT-CHEVY:
[This message has been edited by SUPER-SPORT-CHEVY (edited May 09, 2001).]</font>
Really...
Then what's a supercharger? They do the same thing. And most of the people I know with blowers popped their motors last year, while everyone that I know with N2O, including me, is still running.Trending Topics
<font face="Verdana, Arial" size="2">Originally posted by Formula-91:
Really...
</font>
Really...
Then what's a supercharger? They do the same thing</font>
<font face="Verdana, Arial" size="2">. And most of the people I know with blowers popped their motors last year, while everyone that I know with N2O, including me, is still running.</font>
So? You don't think there are hundreds of guys running around with blown motors from NOS?
All bottle no throttle
91 Formula 1LE 1 of 46
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 supercharger(SN93 upgrade), Ford SVO 24#injectors, Crane AFPR,SLP airfoil, ported/polished plenum, March alt. pulley,Crane Gold 1.6rrs,MSD coil,MSD6AL (5200rpm limit),Holley 9mm wires,Ac delco R43ts plugs,custom chip,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited May 09, 2001).]
[QUOTE]Originally posted by theformula:
[B] Well, hmm blowers are always producing hp ..they don't need to be activated for hp and won't run out after a few seconds like NOS. You don't need to go get a bottle refilled . It's street legal unlike NOS. Shall I go on?
Rock on!
"maksik7
NOS isnt street legal? Is it really? I don't use it so I don't know much about it. Later
-Max"
Nos is 50 state legal, but some local laws prohibit it's use on street drivin aplications unlike "supers&turbos".
SSC
Rock on!
"maksik7
-Max"
SSC
If you have a blower your not considered to be naturaly asperated.If you have nos your not considered to be naturaly asperated.So what is the differance?There is no damn differance if you ask me.I put it on my 305 to help me out because it is'nt eazy to build a 305 and make it real fast.Besides what ever you put on your motor to make it faster makes no differance what it is.A power adder is a power adder.You do'nt say to someone that beats you in a race hey man your cam is bigger than mine thats not fair.All is fair in the race world anything goes.
85 iroc with 305 weind single plane intake, 650 double pumper, msd crap,holley mechanical fuel pump,cam is 230 duration 453 lift, 350 turbo tranny, 2400 stall soon to be 3000, 125 horse shot of nos, 4.10 gears, lower end is built and i shift the 305 at 6500, just for you 305 doubters pull up next to this 305 and get a little
I will let you guys know the results, Call me an optimist, but since he is a 13sec car off the bottle and only running a 150shot...If I get it to hook good, I think I might be able to get close...there are alot of if's in there though!
<font face="Verdana, Arial" size="2">Originally posted by BOWTIROC:
</font>
</font>
Old saying...."If your not doing 12's on motor, your not ready for NOS"
I agree NOS is a great power adder, but if he's 13.0's only.....he's not that fast as is.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
