My Camaro vs. 95 Trans Am LTI 6-Speed
All my mods are in the sig. I ran a 14.1 best on Mickey Thompson ET Street slicks. My friend with the Trans Am ran a 14.2 best time. His is stock except for a K&N fuel injection performance kit. But, now he is getting 4.10 gears to replace his current 3.42 gears. He was just shifting into 4th gear as he crossed the line. Are the 4.10 gears going to put his car in front of mine? Anything I can do real quick to my car? Thanks.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
New Paint
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
<font face="Verdana, Arial" size="2">Originally posted by CamaroX84:
Sorry, don't wanna blow up my new motor. Thanks.</font>
Just gotta know how/when to use NOS.
As far as the 4.10s with a LT1, better put some grease down in his lane, cause it'll be over in the first 60 feet if he hooks up and launches his car correctly.
Seriously dude, don't be afraid of MOS. All the bad stuff that happened to peoples engines happened 20 years ago when N2O technology wasn't as advanced. Now its rare for someone to trash a motor on NOS unless they misssed a shift with a stick trans, or over rev the motor or the fuel pump ****s on them.
Don't be scared....
I think you need a dyno to get your car dialed in. It should go mid 13's on that combo easy.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
I would seem to think that the 4.10 gears will hurt him. On the 3.42 gears, he was spinning his tires for the first 60'. Won't he do it more with 4.10s? Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
Best 1/4 Mile Run:
14.137 @ 94.57 MPH
There is this guy in the car club I belong to and he has a 96 LT1 convertible with 4.10's in it. I think he had headers and exhaust, K&N and CAI.
He ran 13.6X.
You'll get him out of the gate but come 2nd gear he'll pass you.
Like the others said NOS is the only QUICK fix you can do.
Good Luck!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
Member of JFA Crew
He ran 13.6X.
Good Luck!
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
Member of JFA Crew
If he is using the stock radials he will get a worse 60' and hence a worse 1/4.If he can hook up,the 4.10's can knock off about 2-3tenths or more with some engine and intake mods.As for what you can do to your car, judgeing buy your less than average MPH,you have a mismatch of components,IE your cam is outflowing the stock heads and the stock TPI is choking your 355.For a quick increase in some breathing,I would put on some ported SLP runners,port your plenum,(if you haven't already)and install an SLP or homemade ram air.Later port your intake and put on some ported corvette aluminum heads.That should give you times where you should be running(atleast low 13's)
1990 Trans Am GTA,Black/Black Leather,350,auto 3.23,Dual Cats,
SLP Package,Fastchip,GSC's,Brand New Trans with Corvette 2400 stall,Servo/Shift Kit
G-tech 1/4mile(before trans and roasting 1st)1/4mile 13.6@104,now probably 13.2@track with traction/good conditions
stock(track)14.3@96
member www.transamgta.com
Previous Thirdgen
1986 Camaro IROC-Z
stock(track)14.3@96
Previous Thirdgen
1986 Camaro IROC-Z
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
