my 1/4 mile time....
Car: 1990 IROC
Transmission: TH700-R4
how fast do you guys think my 86 Iroc could run? it has the following specs:
LG4 305
TH700-R4
2.73 rear end
edelbrock TES headers
3in cat
edelbrock 3in cat-back
K&N
direct wired electric fan
LG4 305
TH700-R4
2.73 rear end
3in cat
K&N
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
This is what the Drag Racing board is for.
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
89 RS
STILL Looking For:
not fast, not in the 14s ud be lucky for a low 15
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
You should really post this on the organized racing board not street racing but I am going to say this.
15.9 at 86mph!!
I have seen a 130k LG4 with:
Hedman Headers
Full exhaust
Stripped engine compartment.
This is the best it could muster on the strip.
Dont feel bad though most people are highly inflated about what their cars can go.
84 Z28 383
Stripped w/Cage back halved w/ladder bars and coil overs and 9 inch
700R-4 3.73
15.9 at 86mph!!
Hedman Headers
Full exhaust
84 Z28 383
700R-4 3.73
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
My Lg4 sports coupe wont run Low 12s
83 berlinetta currently 350/350 3:42 gear,2500 stal,3inch exhaust,2 1/4
exhaust manifolds,comp cam 268,performer intake
L69 dual snorkle aircleaner 3160lb
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
86CamaroDan
Sep 29, 2015 10:08 PM
