Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
92 Camaro vs. 99 Lightning
Old Aug 10, 2001 | 10:28 PM
jamesbern's Avatar
I have a 92 Camaro with a 383 and a race built 4L60. The engine is dynoed at 440 Horsepower and 465 ft.lbs torque. I haven't yet upgraded my rearend from the stock 2.73's, but the car is very strong. His lightning is stock. Who will win this race and what will my e.t. be approxiametly.
Old Aug 10, 2001 | 11:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Hmmm Im pretty sure you will whipe the floor with him!
Old Aug 10, 2001 | 11:59 PM
Ski89Z28's Avatar
Those Lightning's are fast!!
I've heard they run STOCK between 13.5 and 13.2! The newer models.
The 93 - 94 models were 15 second 1/4 mile times.
A 383 should get into the 12's with good gears so I think it could be a close race. He may have you out of the hole but you might start to pull on him at about 80 - 90 mph.
Is the 383 a carb or TPI? Any suspension mods would help you too.
89 IROC 350 Auto
MSD 6AL
Custom DUAL Exhaust
Edelbrock Performer 6085 Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
And Free mods.
(stock intake, runners and suspension)
13.879 @ 98.90 mph (with 2.77 gears!)
Moderator of http://www.iroczone.com
[This message has been edited by Ski89Z28 (edited August 10, 2001).]
Old Aug 11, 2001 | 01:54 AM
HrdRockA4305's Avatar
Hmm the lightnings I've seen around here usually run low 14's at the track from what i've seen. But if you've got a 440 HP stroker like you say, the only thing you'll need to beat him is traction. If you hook, you've got him easily.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/122,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Aug 11, 2001 | 08:14 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
the '99's are not as fast as the '01's..thats why a lot of lightning owners made a big stink about the '01 model..ford really upgraded this years model..a '99 is good for low 14's high 13's at best...basically..you'll destroy this thing..unless something REALLY messed up happens
:knocks on wood:
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Aug 11, 2001 | 01:24 PM
90Iroc-Zee's Avatar
I went to the track a few days ago and the stock 99 ran a 13.7 @ 101mph (not to sure about mph, thought it was 101). I was talking to the guy, his buddy with a catback, pullies, ignition, and other tiny **** ran a best of 13.2 @ XXXmph. Those things are quick. If his is stock he will go high 13s, if not, your in trouble.
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Also newly modded w/o track times:
Holley AFPR, Underdrive Pulleys, KYB Shocks and Struts, Crane Ignition
Old Aug 11, 2001 | 03:55 PM
Good point, small mods do really help those things a lot. I saw in a mag. where they put on a new MAF, k/n, and a chip and it picked up like 40 or so RWHP at least. Thats a freakin potent pickup.
Old Aug 11, 2001 | 04:57 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
99 lightnings are really stout from anything below about 40mph. My daily driver is a lexus GS400 and i had one pull me pretty good until about 60. By about 70 he was not gaining anymore ground. But, if ur 440hp is configured with the right drivetrain (gearing and suspension), you will kill him. You should be able to run 12s with that combination
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BADNBLK
Nov 16, 2016 09:12 AM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
