Street Slicks or Drag Slicks
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
I run at a local 1/8th mile track. I need to purchase a set of slicks. Should I use a street slick or drag slicks. What would you recommend? Also what sizes should I be looking for.
88 Camaro SC 350 bored .030, flat top pistons w/ valve relief, Stock GM Vortec heads, edelbrock air gap rpm intake and 600cfm. posi 3.73
Micket thompson ET Streets 26x10.50's.....that way yo can drive on the street if need be.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Holley 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
