Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
What tires fit?
Old Sep 26, 2001 | 10:24 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
What tires fit?
Since I got my 4.10s I wanna put taller and wider tires on the back. I'm debating between 255/50/16 or 265/50/16. Will 265 go on with no problem? What is the hight of 255 and/or 265?
Thanks in advance, guys
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear.
Dealer instaled:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(50), Harwood fiberglass hood.
Flowmaster 3" Cat-back exhaust,TB coolant bypass,B&M Ripper shifter, Centerforce dual friction clutch, Ported & Siamesed Plenum matched to SLP Runners, March Power/Amp Pulleys, Richmond 4.10 gears. (???HP)
Old Sep 26, 2001 | 10:44 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
You probably don't want more than 255's on 16x8 rims... 255/45/16 is probably closest to what you want... depends on the size you ran stock... GTA's came with 245/50/16's if I remember correctly.... so yeah, 255/45 would match that well...
Old Oct 15, 2001 | 07:59 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Well, I slapped on BFGoodrich 265/50/16 and I have to say it's much better as far as traction. Still, with 4.10s, I'm gonna go with slick radials, for the track.
The taller, wider 265s fit well with room to spare. Only an inch taller and an inch wider. Didn't change the car's stance. Now the tire hight is 26.4 inches so I reduced the 4.10 ratio a little.
Street Lethal
Apr 30, 2019 12:14 PM
Djmathis123
Aug 24, 2015 02:53 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
Djmathis123
Wheels and Tires
Aug 23, 2015 11:34 AM
