what would it take to run 13's
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
hello everybody I have 89 formula l-98 63000 miles runs strong, mods are UD pulleys
CAI
ported runners and plenum-airfoil
and a chip from pcm-for-less
what else would it take to get into the 13's no nos.thanks
CAI
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: what would it take to run 13's
Have you done headers and exhaust?
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
no headers just a flowmaster muffler was on the fence about headers I read a lot of posts of people having issues with them leaking will see would like them but not sure yet
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Yes they help but really need exhaust headers to make full use of everything. Base timing to 8 deg and 91-93 oct
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
I HAVE TRIED ADJUSTING THE TIMMING I CANOT GET A WRENCH OR SOCKET IN THERE TO BREAK LOSE THE DIST NUT I PURCHASED THE DIST WRENCH STILL NO LUCK ANY SUGGESTIONS
Car: 89 Iroc-z
Transmission: TH400
Dizzy wrench is all you need but may need to remove coil and bracket to get to the hold down bolt
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
headers are generally always a plus!!!! I have hooker shorties never a leak, used to have headman long tubes on a 70 monte carlo & the flanges were thin & I kept having leaking issues so I've stayed away from them. There is a lot of great advice on headers on this forum, but headers are a great idea.....
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great that's good to know after world of wheels I might really look into putting some headers on. Thanks that would make it a lot easier if I took the cap off never thought of that, cant wait until the weather gets better.
Car: 1992 Camaro Z28
Slicks on a well running L98 could honestly probably do it. Sticky track, good tire, good air, you're pretty much set to tick off a 13.9. Full exhaust would certainly help. It's easy, no leaks if you're mildly intelligent.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I couldnt get near that and thats with BFG drag radials chip headers flowmaster exhaust and a K&N filter and this was a fomula that dont have all the GFX to weigh it down??
I don't know what to tell you. I have a 1992 which is a little heavier than the earlier years, certainly more than a Formula. Ran a 14.4 bone stock with a 2.5 second 60 ft. Laugh at me, I deserve it yes I know. Point being, it was on a slick track with horrible street tires, and I trapped 98 mph. Surely on slicks on a grippier track a 13.9 was possible. Maybe you need a tune, or just a tune up?
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
thanks guys we will see track opens end of march or early april depending on weather I will update and post times
Engine: LQ4 ls 6.0
This is what I remember 1988 Pontiac Firebird Trans Am GTA 0-60 mph 7.3 Quarter mile 15.7 thats on street tires I ran about 15.0 on drag radials with no spin and that came from http://www.zeroto60times.com/Pontiac...mph-Times.html
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Engine: LQ4 ls 6.0
That's not just research I had a white one it had exhaust chip and it ran high 14 s on street tires on drag radials it would run low to mid 14 s
Car: 89 Iroc-z
Transmission: TH400
My car first hit 13's on street tires with nothing more than hooker 2055's 3" flowmaster, and 2800 stall. 2.77 gears even. 1.89 60' amd 13.89 at 97-ish mph i think it was.
L98 with all the bolt ons and drag wheels touch 12's. I went 12.99 and 12.95 at 103.8 in 188 ft DA air. 3400-3450 lbs race weight
They can scoot. If yours doesnt its either alot heavier or is a tired motor in need of a tuneup and refresh build, but mine had 160k on it so hard to say how tired it was
Engine: LQ4 ls 6.0
No it ran good just had a fuel pump problem and it was the 350 formula tuned port
Engine: LQ4 ls 6.0
http://www.musclecarfacts.com/classi...ird-statistics I was just looking around and found this
Car: 1990 Iroc-Z
Engine: LQ4 ls 6.0
Car: 1990 Iroc-Z
I think I even saw that a 2002 trans am had 275hp which is completely wrong. That's just another example. I looked at the article through my phone so I could be wrong but that makes me not trust any numbers on it. Senior Member
Engine: LQ4 ls 6.0
This is what it ran with motor trend this is their page in 1988 it was at 90 mph and looks like 15.6 in the 1/4
Engine: LQ4 ls 6.0
Then who does they have the track the drivers the cars brand new cars with no mods this is all I have to say
Car: 89 Iroc-z
Transmission: TH400
There are quite a few out there. Mine wasnt brand new it had near 160k miles on it when it went 12.9's. but engine was mostly highway mileage and babied.
True test is to dyno it. Strong bolt on l98's with different intakes or atleast big tube tpi stuff should be well over 240-250 hp. Some 260's. mine was 254 lean. Would have hit 260 whp with more fuel and it ran 12's on that lean tune
Engine: 305TPI
Another article to look at. This is from our own TGO multimedia pages.
https://www.thirdgen.org/secret_chevys_mt_june_1990
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
I think its funny how there is such a difference in what articles say cars run, cant wait until spring comes and find out.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 1983 G20 Chevy
Transmission: 4L60
Definately not an impossible time, I have seen a LT1 Auto car with an intake and muffler swap run similar times in good weather as well.
That being said I have a 5,300 lbs truck that run a 13.98 with only 296 RWHP. In a car that is a good 1,500 lbs lighter I could see the same driveline picking up over a full second.
Car: 89 Iroc-z
Transmission: TH400
Yup 254 whp 315 wtq. Same day my friends 95z28 with headers exhaust 3.73's and tune thru stock auto went 12.9 at 106. On street tires. But thats more like a 275-280 whp car. I seen stock lt1's dyno 260 thru auto
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 89 Iroc-z
Transmission: TH400
You'll want to monitor air conditions at your tracks altitude to see what the air density altitude is. Closer to sealevel the better you will run.
My trans am ls1 car would run 12.1's at -800 feet da. Up in 2500 it would run 12.5's
My l98 record run was 188 ft and normal summer air would run 13.2-13.3
Car: 91 formula
Engine: 350 tuned port. bolt ons
yea. Im hoping my combo will get me into the 13"s First time running at a track this coming spring. But I would think a well tuned bolt on L98 is into the 13 sec Range for sure.
Car: 92 ZR-1
Engine: LT-5
Transmission: ZF-6
Axle/Gears: SuperDana 44 4.10
Heads, cam, headers using EBL. 84 Xfire on street tires. It dyno'd at 285/347.
Best ET was 13.3, best trap 104.5. Weight was 3250 wet. The run in the video was 13.7.
And yes it had the Xfire manifold and twin TBIs.
Car: 1992 rs 355 TBI **swapped**
Engine: 80 Ford Fiesta GHIA dual carb
Transmission: 72 Cutlass S 350/350 3.42
Axle/Gears: s10 tq converter/stock rear gear
My dads L98 hit 13's stock, zero mods not even a k&n engine wise. It ran slicks and he had what he called a cheater converter, stalled at just over 3k and hit hard.
I didn't like it. Street tires were impossible, it made too much noise lol.... But it did lock up so he could cruise it
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
