Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
sbc bored 40 over
Old 09-12-2015, 06:29 PM
deemoney's Avatar
sbc bored 40 over
I need help guys ima keep it easy I have a sbc 400 bored over 40 with speed pro flat tops 4 valve release stock crank that's it I'm trying to build a nice street strip car o and I have a 292 501 lift comp cam nothing is installed but I want 500+hp what do I need to change or buy help help help!
Old 09-13-2015, 12:31 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: sbc bored 40 over
500 HP is doable but not easy nor cheap.
You need compression 10:1 bare min, 11:1 better.
You need great heads. 200cc intake port min, 210-220cc better for a 400 sbc
Something like Brodix wild things, AFR, Profiler, etc.
You will need closer to .550" to .600" lift cam... Roller cam would be the best way of going. Something in the 240-250* @ .050" range
7/16" rocker studs
Full roller rockers. Billet alum or stainless steel
750 cfm double pumper, min. 850 cfm would be better for a 400
Single plane intake like the victor jr. min.
Good oiling system, 7qt pan, windage screen, rear main baffle, etc.
1-3/4" tube headers
Old 09-13-2015, 04:34 PM
deemoney's Avatar
7/16" rocker studs
1-3/4" tube headers
OK so the Pistons I have is fine?
Old 09-13-2015, 04:35 PM
deemoney's Avatar
And aluminum or cast iron heads?
Old 09-13-2015, 07:02 PM
Car: 1988 Camaro
Aluminum heads like Brodix, AFR or profiler
Pistons... Maybe... Speed pro flat top 4vr does not tell me enough about them. Are they cast, hyper or forged? With a 500 hp build you really want forged
What cc are they? The piston CC, bore, stroke, deck height, head gaskets, and head camber CC sets your compression ratio.
How deep is the valve pockets?
With a bigger cam like needed to get into the 500 HP range, you MAY have valve to piston clearance issues and may have to fly cut the valve pockets deeper in the pistons or replace pistons.
FormulasOnly
07-23-2018 08:47 AM
gixxer92
05-18-2017 11:20 AM
darwinprice
17
10-11-2015 11:51 PM
Bradsaundry
10-07-2015 04:35 PM
hartsmike
10-02-2015 07:11 AM
Quick Reply: sbc bored 40 over
