Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
1982 diff and M/T slickd
Old Oct 6, 2017 | 05:05 PM
aussiesteve's Avatar
Car: 1982 z/28 Right hand drive
Engine: 377 AFR195 750DP Solid cam 10.25:1
Transmission: TH/350 3200 stall spohn conversion
Axle/Gears: 10 bolt 3.42:1 Eaton Trutrac.
got an 82 with a 408 and th350 stock rearend with an eaton trutrac centre fitted with 3.42 richmond gears.
car runs 13.2 @ 107mph on 255,60,15 BFG T/A radials tires and bad traction issues.
just bought 2 Mickey Thompson Street ET rear tires
will i break the diff....
up till now i keep out of the water box at the strip and try not to smoke the tires in stage area
worried about braking centre in diff or axles.
engine is about 400 hp with simmilar torque.
Old Oct 8, 2017 | 02:33 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: 1982 diff and M/T slickd
Some things I have done to help my relatively stock rear last:
1) no wheel hop!!
2) burn out just in front of the water (after wetting tires) and drive out of the burnout and to the line. No dry hop!
3) load the rear at the line by creeping into the second yellow with your foot on the brake. You want the pinion teeth in contact with the ring gear.
4) did I mention...NO WHEEL HOP!! If it starts to bounce, get out of it immediately.
I have over 300 passes on my 1990 rear (a little stronger than yours). All of them in the 400RWHP range.
Old Oct 9, 2017 | 04:14 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
The fact is that if you hook up with any kind of power you are going to break that diff. Time to update. If your trying to drag race why worry about that every time you are leaving the line not to mention the thought of hitting the wall or someone else in the lane next to you.
I would invest in a stronger rearend setup over the winter. That way your safe!
Old Oct 9, 2017 | 04:37 PM
there are hundreds of these cars on this site running 12,s with these difs....if and when i get $3000 for a 9 inch and pay $1400 to ship it here and pay taxes i will do it tomorrow
... i have had 37 runs and no problem but with slicks and more rpm launches there will be the chance of walking home...thanks anyway
Old Oct 9, 2017 | 04:38 PM
i am buying a 427 shafiroff in december and a diff mid next year. until then i am having fun and beating some good cars @13.2..
Old Oct 10, 2017 | 02:57 AM
Z28FAST1's Avatar
Based on you trap speed you should be ok on the 10 bolt. Automatics seem to get away with launching on 10 bolts vs manual cars.
What's your current 60 ft time?
Old Oct 10, 2017 | 06:40 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Right running 10 bolts, more than likely not doing dig races with slicks. It'll break, plan on getting something better
Old Oct 10, 2017 | 11:32 AM
pancherj's Avatar
Car: 1990 IROC
I have over 300 passes on my 1990 rear (a little stronger than yours). All of them in the 400RWHP range.[/QUOTE]
Maybe I have been lucky...but I wouldn't call this a time bomb. I was scared of the rear when I first bought the car. A good friend of mine was running a 7.5 in his 1980 Malibu drag car that routinely ran low 10's. He was the one that encouraged me not to give up too soon on the 7.5. So far, I have been happy. Will it break? Sure. I also broke the G Force 9 inch in my 2010 Camaro on street tires. Wheel hop and incorrect gear setups can wreak havoc!
Old Oct 10, 2017 | 02:05 PM
izcain's Avatar
Engine: 584
Everyone always goes for the HP before being able to put it to the ground. I understand it is the funner thing to spend money on but with what you have it sounds like if you spent some time back there it would be a lot quicker then 13's
I'm not trying to offend, I just know how it goes with those rearends. I had street tires and ran 12's for years with the old ten bolt. First pass on the slicks boom and that was it. All it took was for the car to hook and actually want to go. So I am speaking from experience. This was with all the goodies too, girdle, bracing, Richmond gears, moser axles, spool the works.
Old Oct 10, 2017 | 02:06 PM
izcain's Avatar
Engine: 584
Originally Posted by pancherj
[I]I have over 300 passes on my 1990 rear (a little stronger than yours). All of them in the 400RWHP range
Yes you have been lucky. Some have more luck then others.
Old Oct 15, 2017 | 03:46 AM
60 foot times 2.25,,with street tires BFGoodrich T/A radials..
and unable to give it heaps off the line..
running 2500 stall and with the Mickey Thompson Street ET tyres GOING ON THIS WEEK,,, i should go better
