Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
302DZ Crossram build
Old Feb 13, 2026 | 06:58 PM
NoEmissions84TA's Avatar
No, not another 302 cid engine build. But if you had the crossram intake (either single or dual) and were determined to put a SBC under it, what would you choose for street use? Assume your typical street car - 3500#, 3.73 rear gear, 28" tall tires, shift at 7000 rpm, no racing fuel. I love 8000, but let's be practical here. And 6000 rpm is boring.
the cross ram intake | Grumpys Performance Garage
I guess that Grumpy already had this discussion: the cross ram intake | Grumpys Performance Garage
... keep in mind that the cross-ram intake works best on a 350-406 with a cam and gearing that keeps the engine in the 3500rpm-7000rpm band, so both the cam and the intake design match that OPERATIONAL RPM BAND and REQUIRES a decent set of high flow rate heads, (generally look for heads that reach or exceed 250cfm at .600 lift) with a matching 10.5:1-12.5:1 cr and generally a 4.11:1-4.56:1 rear gear and manual transmission, when road racing, to operate correctly in its intended rpm band and flow rate. you could drop back to a 3.73:1-3.90:1 on a street car.
What do you think?
Old Feb 13, 2026 | 07:35 PM
countryracer69's Avatar
Re: 302DZ Crossram build
I build engines. Mostly circle track, lots of resto-mod stuff, and a bit of drag race plants. With sbc builds my go to's are 383 based for torque and 377 based for high rpm and HP. Even built a stroker 305 once with a DZ302 cam. Was a very lineal power.
Hello, Michael
Carburetors
16
Jul 24, 2013 11:54 AM
Matt61609
Carburetors
23
Feb 28, 2012 05:37 PM
turbotater
Alternative Port EFI Intakes
Jan 22, 2011 01:29 AM
84 z28
Oct 11, 2006 02:56 PM
ditchbangr
Carburetors
Jun 21, 2006 05:11 PM
