Theoretical and Street Racing Use this board to ask questions about street racing, discuss your street races, and "who would win?" questions. Keep it safe.
are far off is the performance range
Old Mar 28, 2002 | 10:38 PM
CaMaRoIrOcZ_1_'s Avatar
lets say if i get a 1990 Iroc Z wit 350 and standard and someone else has a 1999 z28 wit 350 and standard. what will i need to get to get my iroc z down to the performance level of the z28.
Old Mar 28, 2002 | 10:50 PM
Treview1's Avatar
a good amount of work
Old Mar 28, 2002 | 10:52 PM
5.0mustang's Avatar
A lot of cash, time, and patience, oh ya and a little Nitrous wouldn't hurt!!!
Old Mar 28, 2002 | 11:02 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
if you have a 90' IROC 350 with a 5 speed which you won't find in stock form should run low 14's stock. A 99 Z28 6 speed can be running anywhere from low 13's to high 13's. I say with a good header-back exhaust,gears,good suspension,bigger cam,good tires,ignition upgrade,and a litte shot of squeeze you could hang with a stock 99 Z and even walk one.
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
Well, in 90 the 350 in the camaro was putting out around 245 HP and 345 Ft/Lbs....in 99 the 350 in the Z28 was putting out around 305 HP and 325 Ft/Lbs I think. You have about 20 more Ft/Lbs. of torque but he has 60 more HP. You wiegh less but he would still win in a race. It's gonna cost some $$$ but it is very possible. In 90 the 5.7 was only available with an automatic but you start with 3.23's. Full exhaust, a bigger cam, an open element air cleaner, some better gears, and some under drive pulleys could probably make up for that 60 HP.
Old Mar 28, 2002 | 11:05 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
All L98 cars were auto.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Giocio
Oct 1, 2015 12:20 PM
