Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
please help me with my horn
Old Apr 26, 2002 | 09:13 AM
yOp 84 Recaro's Avatar
Hi..
I've posted this elsewhere .. but posts fly through the general tech section so fast. Anyway my horn is toast. I've checked the fuses and all is well there. I press the horn and all I get is a faint click. I heard something about rinpping my steering wheel apart and checking to see if its still hooked up.. is that what I need to do.. and if so how do I go about that..
thanks..
Old Apr 26, 2002 | 09:55 AM
IROCKER's Avatar
I'm not sure if the TA is the same as my IROC, but you just unplug the battery and then take the horn cap off. It should just pull straight off. But most likely it is the actual horn itself which I believe is hidden inside the front fender. Because it's tucked away, it's very suseptable to dirt and moisture build up so it may have to be replaced.
Old Apr 26, 2002 | 10:04 AM
tucked away in the fender .. hmm .. that dosn't sound like a fun thing to get at... can anyone verify my 84 horn is hidden in my fender and if so does anyone know how I go about changing it..?
Old Apr 26, 2002 | 12:01 PM
IROCKER's Avatar
Depending on which side it is, you might have to remove the battery or the vapour canister. Shouldn't be too bad as long as you don't have king kong size hands. It won't be that hard.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
