Has anyone ever had trouble with their V.A.T.S.?
Car: 1990 Iroc Z Convertible
Engine: LB9
Had the car out for most of the day yesterday, it was running incredibly good for a change. So the wife decides she wants to go to the Home Depot to pick up some paint. So I drop the top and we head out into the magnificent sunshine. All is going well, until I decide to make a quick stop. We stopped for about 10 minutes, when we all get back into the car I turn the key and absolutely nothing happens. This has occured on 2 other occaisions, once my wife tried to put the key in upside down, the other time was the same as this one(no irregular key incertion). These incidences happened nearly 2 years ago and up until yesterday had not occured since. I knew it was a vats thing, we waited 20 minutes and sure enough with the first turn of the key the ever expanding bottomless moneypit came to life.I'm just wondering if any other 1989-1992 owners have expierienced sporatic vats problems? Has anyone bypassed the system?
Car: 92 TA vert
are you sure its the key? there are lots of other things that will prevent the car from starting. i had a problem one time similar to yours. turned out to be the trany switch was not in the park postion and the computer still thought it was in gear.
Engine: LB9
I did not touch the gear selector, I waited for 20 minutes and the car started immediatley. I posted this problem when it first happened 2 years ago and it was sujjested that the ignition cylinder might be getting worn and thats what was triggering the problem. My car is a fairly high miliage car (200 000 km) so these problems keep poping up.
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
never happened to me
This has never occured on my Formula but then it has 73,399kms on it.
RP.
RP.
Re: never happened to me
RP.
RP.
