Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Need new injectors (AGAIN !)
Old Jul 8, 2002 | 11:24 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Well after my last trip to the GM dealer and after paying yet another $90 for diagnostics -- the guy used a multi-meter just like the one I bought last week that didn't work -- and found that 4 of 8 injectors had low, low resistance in other words I have yet another batch of FRIED Multecs. (Are you listening easySPEEDcamaro ?).
The readings were 1.5, 17.0, 7.1, 16.9, 11.8, 16.8, 10.2, 17.0...
So like any TRUE f-body guy I recodnize that a repair is an upgrade in disguise. Here is what I am trying to find out.
If I stick with the 305 what is the best rating for an injector ? 19lbs ? 22lbs ?
I have heard that 24s are not very effective on the 305.
I have read on the TPI board that Ford SVO (gulp) injectors are a good replacement for the 305.
What about brand names any preferences ?
How about who or where to buy them from ?
Any comments would be appreciated.
thx in advance,
RP.
Old Jul 8, 2002 | 11:51 AM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
This may not be the road that you want to take(being the cheapest) but the Accel's are probably the least expensive NEW injector that you'll find. I can't vouch for the longevity since I've only had mine a year but so far so good(although I have not tested them lately). I got mine from cruzin performance in Michigan for $229.00 USD. By the time they were in my hands it cost me around $480.00 CDN. They are a Bosch style injector. Rich, who is the owner of Cruzin performance is a really nice guy. He'll be able to answer any of your questions. The website is at this address www.cruzinperformance.com. You might want to post this on the big board to see if anyone has any other sujjestions.
Old Jul 8, 2002 | 11:59 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
hehehe
towed the car to the mechanic this morning
cost me $110, and boy did we have fun getting the car out of the underground garage!
brought it to the mechanic, he said my clutch is fried. like... so fried that u can change gears without touching the clutch lol
he told me not to go with a performance clutch and just put the regular one in, it'll last longer.
Old Jul 8, 2002 | 12:47 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
What year where the Multec's used 'till? Where they used in the 4rth generation cars?
Old Jul 8, 2002 | 12:52 PM
palric's Avatar
not so
Apparently they were used from '89-92 or so says Rick at Cruizin Performance. They must be junk cause he talks about them with vEhEmeNcE !!!
Well I can't say for all years of Multec but the ones I have used ('91) are a black hole for cash. Junk. JUNK. FREAKING JUNK. My car would be in perfect health if not for that junk man does it run bad with a couple of crappy injectors. Well now I am just venting...
Hey what about Aug 10th ? Are you going to come down ?
RP.
Old Jul 8, 2002 | 01:00 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Well, my injectors are from a '94 Z28 so I hope they aren't Multec's. I had them cleaned and flowed at LPE last year. My car runs kind of strange and i've allways kind of thought that it was just the engine and the ECM having an argument.
I have no idea if i'll be at the August 10th drag day. If I have the rest of my stuff installed by then i'll do my best to show. I'd like to be able meet up with you guys sometime this summer but it really is a long drive for me.
Old Jul 8, 2002 | 02:16 PM
trigger GTA's Avatar
Car: 92 TA vert
i went with the ford injectors only cost me 400 for a new set of 8 i got them in town at marken performance a few years ago.
suckes to have to replace them. its not much of an upgrade on a stock engine. you would also have to change the program in the chip if you go bigger.
Old Jul 8, 2002 | 02:51 PM
palric's Avatar
bought the Accels
Thx for the advice. I called Rudy Held and got 8 x 19lb Accels for $505 CDN tax in. They are supposed to be here on Wednesday so I will be Toyota'ing around till then.
Lets tally this up, $90 for the EGR that did not fix the problem, 8 injectors (again) for which I am out $500 this time and yet another $90 for a GM diagnostic to tell me my GM injectors are junk.
I am back in the Toyota until the Bird gets fixed and down about 150hp (Tercels make 93hp) hey it really sucks to be me this week.
RP.
Old Jul 8, 2002 | 07:14 PM
88 IROC BOB's Avatar
palric, FWIW I put in new Accel 23# injectors last year and haven't had any problems so far. I bought them from Cruzin too.
Bob
Old Jul 8, 2002 | 07:25 PM
palric's Avatar
good
Bob
thx for the heads up. I bought the Accel 19lb'ers from Rudy Held hopefully they show up before winter.
Rick & Cruizin says they are Bosche with Accel's name on them and of high quality. I hope so I am tired of this injector grief -- makes we wonder about carb's again...
RP.
Old Jul 8, 2002 | 09:21 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Re: good
RP.
Long live the mighty carb!!!
Old Jul 9, 2002 | 10:44 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Yeah, ok Dave And what kind of mileage where you getting?
Old Jul 9, 2002 | 12:59 PM
nblanchard's Avatar
Carbs are yukky and make you gain weight :P
Old Jul 9, 2002 | 06:44 PM
palric's Avatar
multi-meter testing of injectors
I figured out why my multi-meter test showed the injectors ok and the GM dealers showed 4 bad injectors.
I tested the injectors COLD and the GM mechanic tested them HOT. I just minutes ago tried them HOT and sure enough I get four bad readings....
What a FREAKing dummy I am I blew $100 at GM cause I never thought to test them hot. Where is my boot I am going to sh*t kick my butt from here to Penantanguishene and back.
adious,
RP.
Old Jul 9, 2002 | 07:50 PM
nblanchard's Avatar
Ahhh yes Rick... the problem was occuring when hot, so... .wlel you know now :P
See ya when you get from penetang
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
