Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
View Poll Results: Which of the three is most restrictive?
Phelenum
20.00%
Runners
20.00%
Intake Manifold
60.00%
Voters: 10. You may not vote on this poll
Poll! Which do you think in your opinion is most restrictive??
Old Sep 13, 2002 | 03:22 PM
88redxtsy's Avatar
In your own opinion, which of the three in our TPI system is most restrictive for performance and what would you do to improve it? The phlenum, runners or intake manifold? Go nuts guys. I think it's the phlenum and runners. A larger phlenum would draw and hold more air and larger runners would be able to deliver it to the manifold.
Old Sep 13, 2002 | 03:27 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
In order of restriction..........
1. Base manifold
2. Runners
3. Plenum
Actually, I don't consider the plenum a "restriction". It's shape and design is a function of the TPI systems long runners.
Old Sep 13, 2002 | 03:28 PM
92zeddar's Avatar
Just like Acceld says!
Old Sep 13, 2002 | 03:36 PM
88redxtsy's Avatar
Would it be fair to say then if one was to purchase shorter runners with a stock phlenum, the gains would not be as noticable if the shorter runners were used with an aftermarket phlenum?
Old Sep 14, 2002 | 01:44 AM
ninety1TAgta's Avatar
Ive never seen an aftermarket plenum in the same tpi style as stock... But what your talking about is pretty much the super ram. shortened runners and a big plenum.
After porting runner and plenum and evaluating the base on the car I can see why everyone says its the most restrictive. Not much you can do with stock runners other than clean up that lip where the tubes meet the flange. I dont think a stock plenum is terribly restrictive or anything but porting it is easy and makes a pretty decent difference at WOT IMO. You would be surprise how poorly made the 2 holes for the TB were made... I also cleaned up the bolt nibs that enter the plenum to make them a bit more aero dynamic, doubt it make a difference but I figured it cant hurt.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
