Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Holley carb question
Old Sep 20, 2002 | 08:25 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Hey all those that run carbed engines, I just picked up the spring kit for my vacuum secondaries. On Dyno Day, I discovered that my secondaries weren't opening until very late. Too stiff of a spring, so I bought the kit. I have installed the short yellow spring, after I had tried the longer yellow spring. What exactly am I looking for? I didn't notice anything overly different.I am not too knowledgeable when it comes to fine tuning a carb. I will be bringing the kit to the track tomorrow, so if anyone has any insight, that would be great.
Old Sep 20, 2002 | 08:58 AM
Slade1's Avatar
Take it out for a WOT run in 3rd gear, if it still has a bog and then runs strong, wrong spring.
You want a looser spring that allows the secondaries to open gradually as I recall.
When the secondaries opens suddenly, you'll notice a big bog in the engine as all of the sudden there's a great increase in air, then it'll recover and run strong.
When it opens gradually, it should follow the curve quite nicely and accelerate strong till you max out the flow of your setup. You shouldn't feel a thing until you're maxed out.
Old Sep 20, 2002 | 09:17 AM
darbleinad's Avatar
Car: 84 Trans Am
kevs87, can you bring that overdrive tranny bracket for the holley to sparta, i may buy it off you. thanks
Old Sep 20, 2002 | 09:50 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Hey Brad, no problem. I will put it in my car now, so as not to forget it.
As for the WOT, it seems o.k.Then again I didn't try it in 3rd gear, just o/d. I will try it out at the track. Maybe someone can see/hear it better than I can.
See ya tomorrow
Old Sep 20, 2002 | 09:54 AM
Slade1's Avatar
The secondaries suddenly opening like they were before will be very dramatic, recall on your curves that great dip... that translates to an incredible loss of power as the engine was flooded with air. If you managed to eliminate that in a 3rd gear run on your car, then it should be fine.
Old Sep 20, 2002 | 10:02 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
check your plugs..
Daz
Old Sep 20, 2002 | 07:40 PM
darbleinad's Avatar
Car: 84 Trans Am
and dont run the car in OD at the track, leave it drive
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
