Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Engine Bolt Sets
Old Sep 28, 2002 | 06:53 PM
Demon355's Avatar
Engine Bolt Sets
There any sets that you can buy that have all the bolts you need for a 350 TPI engine? I think I'm missing a few specific bolts, if I'm not mistaken, that are for the runners. Well, there is this faily big hole in one of them on the drivers side. Now I have these 2 screw things that look like sensors, but I didn't think they went in the runners. Anyone help me out here? Oh and my distributor won't go back in. I have it marked and all, and I tried to install it today and there is about half inch gap between the distributor and the intake. Any thoughts? There are so many electrical connections to make, I am so frustrated about them even though I know that when I get all the mechanical installed, I can hook everything up but I take one look at it and I'm like holy sh*t! I'll get through it like so many of you did Thanks in Advance!
Old Sep 29, 2002 | 04:12 AM
nblanchard's Avatar
First of all, distributor may not be going in because the oilpump shaft isn't lining up....
The big hole on the drivers side may be you're hole for the 9th injector? Only sensor is in the plenum, egr, and intake base... none in the runners...
You can buy stainless bolt kits, but its only for the plenum, runners and throttle body.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
hectre13
Aug 26, 2015 08:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
