Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
1/4 mile trick I read about last night
Old Oct 12, 2002 | 06:43 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Hey All,
I read about this tip the other night. Seems this guy was trying to get that last iddy-bit out of his car and looking around for some tenths to steal back bought a shorter serpentine for the track that cut out his power steering pump and A/C.
According to this guy NOT ME (before everyone starts jousting with me !) he got back a clean two tenths with the short belt ?!?!
I've been thinking about it -- why am I turning my PS unit at the track ? For that matter why the A/C unit as well ? I think I will check out a new short belt they are only $25.
Stock is what 94 inches long ? Probably pull atleast 6 inches off the U-drive pullies took 3 off and I got 10hp well that is a different story eh ?
Just thought I'd pass it along for those of you heading to the track tomorrow...
RP.
Old Oct 12, 2002 | 07:03 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
good luck making that turn at the end of the 1/4 mile
Daz
Old Oct 12, 2002 | 07:32 AM
palric's Avatar
Hahahaha you know I thought about that.... I mean I've never driven my car without PS so what do you do crash into the woods ? Plow into a ditch ? hahahahaha
Old Oct 12, 2002 | 08:59 AM
johnyIROC's Avatar
I drove for 2 years with no power steering in my Camaro. For the 1/4 mile you will have no problem making the turn. It is actually quite easy to turn once you are in motion. But as I'm sure you expected... I have to say that you aren't going to see huge results.
Old Oct 12, 2002 | 09:53 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I have no power steering. Just have to strong arm it. Go for it palric. Anything is worth a try. Get a belt that just runs the alternator and the water pump if it is possible with your setup. It should help a little.
Old Oct 12, 2002 | 11:30 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
Just don't try parellel parking without PS. Once your driving faster than a crawl, its just as easy as a system with PS.
Or, get a set of skinnies for up front
Old Oct 12, 2002 | 11:33 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
LOL! Yeah that would probably be tough. Never had to try it yet,and don't plan on it either. SOme drag lites would help. I need to buy a set for the front of my car. Anyone know someone who has some for sale at a reasonable price? Let me know if so.
Keiran
Old Oct 12, 2002 | 01:41 PM
nblanchard's Avatar
I stick to my theory that the A/C pulley takes next to NO horsepower to turn when the clutch is off!! You can spin the dang thing with one of those tiny fans that take 1 AA Battery.. LOL
Old Oct 12, 2002 | 03:58 PM
Slade1's Avatar
that's why they make underdrive pulleys...
I got a set and yes they do make a difference, you just have to get a proper alternator pulley to keep the voltage up.
Luckilly March also makes a power and amp series set too.
Old Oct 12, 2002 | 04:52 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
why bother using belts?
Daz
Old Oct 12, 2002 | 08:05 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
lol If it's just for one run, who needs an alternator?
Old Oct 12, 2002 | 08:14 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Problem is the water pump. I guess if you are letting cool really well before each run. As long as you have a electric fan that is. If not you have no cooling what so ever.
Old Oct 12, 2002 | 09:34 PM
Slade1's Avatar
Manual fan switches are great for track.. I can keep my temp at 180 till I decide to mash the pedal...
Another matter is why have your coolant pump run so high? I thought about that even as a daily driver, its kinda unecessary, I get caught in downtown Toronto traffic all the fricken time and don't worry about overheating, only at stops longer than 25 mins idling there will I need to turn the fan on, even then I only turn it on at 105 usually.
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Mickeyruder
Sep 2, 2015 02:45 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
