Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Maf
Old Nov 14, 2002 | 01:02 PM
Luva350's Avatar
Maf
Hate to bring this up again...but does anyone have the part numbers for the 2 relays? or can i just tell the parts guy the MAF power and MAF burn-off relays is what i need? I tried another MAF from another car and the same thing is going on.
Hard cold start. So I put my old one back in and gave back the MAF I tried.
Also once i get the new relays can someone tell me how to replace them?
Old Nov 14, 2002 | 01:52 PM
IROCKER's Avatar
Just tell the guy what you need...they should be two different part numbers. The burn-off and FP relay are the same p/n though.
Replacing them take about 5 minutes or less...probably takes more time to get out your socket set then it does to remove the part. Once you get the new parts in hand you should be able to figure it out...two screws hold each relay in...they are on the driver's side of the firewall...and the wiring harness simply clicks in.
Old Nov 14, 2002 | 02:00 PM
nblanchard's Avatar
Swapping the Fuel Pump relay and MAF Relay will diagnose your problem, instead of going on a guess... thats what I did, and when I did that, the car ran fine, so I bought the new relay
Old Nov 15, 2002 | 04:52 PM
Luva350's Avatar
trying hard not to sound like a moron....but if you switch them and one is not working ...how will the car run properly? It sounds good...so i do not waste my $ but u need to explain this 2 me, please.
Old Nov 15, 2002 | 05:04 PM
nblanchard's Avatar
The relay on my car didn't go dead completely.. it was just weak, so it worked enough to run the fuel pump
Old Nov 15, 2002 | 05:29 PM
Luva350's Avatar
oh, ok. How do I know which one is which? I will attempt this Sat.
Old Nov 16, 2002 | 02:09 AM
nblanchard's Avatar
They are the same relay.. onw plug is grey, and one is black.. they are in a bunch of 3... the one in the middle is different, so you want to switch around the outside 2...
Even if the MAF relay is toast completely... you will know if the car doesn't start, because your fuel pump will be out of service due to the bad relay
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
