Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Front end loose
Old Nov 22, 2002 | 12:37 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
Front end loose
Got my front end checked out for like the 3rd time and was told everything is tight....bull****.....its loose as hell.....anyone have the same problem and firgured out what it was?.....i don't wanna replace all components of the front end, but if i can't get any answers i might have to.
1985 Trans Am Lg4
Old Nov 22, 2002 | 08:12 AM
screamin'chickn's Avatar
Car: 86 T/A
Engine: 327
loosey, loosey
Steering Box!, and its fully adjustable, just don't over do it. I'm surprised whoever checked your car didn't check it or even try to convince you to replace it
Best bet is to reference a shop manual or see if anything is listed in the tech area, but the general rule is to have the front end of the car suspended, loosen the lock nut on the top centre of your gear box and gradually turn the adjuster (w/allen wrench) a bit at a time (clock wise), checking repeatedly for slop by visually checking the amount you can rotate the steering column (this is where you need help), without seeing rotation in the pitman arm. It is critical that you don't over tighten the adjuster and occasionally as you adjust, re tighten the lock nut and turn the steering from lock to lock (not running) and make sure you don't feel any tight spots. If you do, back it off a little bit.
Adjustments are very minute once you get close ie. less then an 1/8th of a turn. There are only three teeth on the gear and the amount of play is usually greater near the center line as that is where you do most of your driving, this is why it is important to check the full range of steering as you go.
Hope this is of some help.
K.
Old Nov 22, 2002 | 08:45 PM
Idlehands's Avatar
Car: 1985 Trans Am
yes thx.....i will try it out
Old Nov 22, 2002 | 08:46 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Hey Idle... i still have that 89 Iroc steering box...$100 and it's yours. We could meet up somewhere inbetween us. Let me know???
Old Nov 22, 2002 | 09:56 PM
nblanchard's Avatar
Hmm.. I didn't know about the adjustment... My car started pulling with the road a lot near theend of the summer.. I was thinking the center link... but it could be that adjustment... thanx dood
Old Nov 24, 2002 | 10:08 AM
Idlehands's Avatar
Car: 1985 Trans Am
Yeah Kaz, i just wanna makes sure its the box, and if so i will grab it off ya for sure.
Old Nov 24, 2002 | 10:35 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Sounds good Idle. Let me know.
Old Dec 4, 2002 | 02:28 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
are you talking about a really bad rattling noise?
is that what it is, the stearing box?
Old Dec 4, 2002 | 05:15 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I have always thought my front end was/is a little too loose too....despite being checked out by a couple of people, including friends of mine who are mechanics.
Is adjusting the steering box going to make that much of a difference, if it gives the ilusion of it being a bit tighter, I might just try it out for myself
Old Dec 4, 2002 | 05:19 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I have seen cases when the box gets to much play in it and requires replacing. Wether that is the case here I am unsure.
Old Dec 4, 2002 | 05:20 PM
johnyIROC's Avatar
A bad center link can also put a large amount of slop into it. I had a bad center link and I got like 4 inches of play in the wheel.
Old Dec 5, 2002 | 10:55 PM
Idlehands's Avatar
Car: 1985 Trans Am
what about a weak idle arm????
Old Dec 12, 2002 | 10:16 AM
Idlehands's Avatar
Car: 1985 Trans Am
ok so put the new idle arm in yesterday and that was it, everything seems tighter. Thought i'd let you guys know incase some of you are experiencing the same problem.
Old Dec 12, 2002 | 10:34 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks Kevin....I am going to check that out on mine, but not until the spring....I thought about pulling it out of storage and brining it home yesterday to do some work on it but then I thought with my luck over the last little bit I would hitting some ice and end up slamming into a tree or something, ha ha.
Old Dec 12, 2002 | 10:42 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Glad to hear you got it figured out Kev. Good work. She'll drive like new again.
Keiran
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
