Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
recalibrating needles
Old Dec 29, 2002 | 08:24 AM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
well,
these white face gauges look great but are a pita afterwards..
now my tach doesnt work properly..
how do i recalibrate it?? when i took it off it was at like 2500(thats where it stays when its in the off position)
would i simply put it back on there at that rpm or what..
daz i think you are the only one that i know of that has these...can anyone help??
thanks guys
iroc2nv
Old Dec 29, 2002 | 09:27 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I dont quite understand what you are saying..You took the gauges off and the Tach stays at 2500RPM or you installed the gauges and now its pegged at 2500RPM?Maybe overlay itself is leaning on the needle?What happens when you start the car?Maybe the overlay is rotated..Im assuming the overlays that you have are the same as your gauges..If not its not gonna work
Daz
Old Dec 29, 2002 | 10:02 AM
iroc2nv's Avatar
Axle/Gears: 3.45
no...im sorry for being vague..
when i put the overlays on, my tach showed that the rpms were at 2500... so i took the needle off and replaced it back when i was done...
but now when i start the car(even in the on position and not started) the needle drops right down to 0 and when i give it gas (in neutral) once it hits 2500?? or so rpms the needle starts to move..
there is no restriction as far as the gauges are concerned, but i did notice that when i physically move the gauge to 2500 (it seems that is the middle number) if i go a little above 2500 it goes to the 7000 and stays (car not started but key on) and 2499 and under it drops to 0
do i need to get it computer calibrated or what?? i hope that this helps a bit more..
thanks man
iroc2nv
Old Dec 29, 2002 | 10:40 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
you dont need to recalibrate the speedo when putting overlays..Why did you pull the needle off?It seems like either you didnt put the needle back right or you broke the gauge..
daz
Old Dec 29, 2002 | 12:02 PM
iroc2nv's Avatar
Axle/Gears: 3.45
naw i didnt put it on right...i took it off while the car was running and put it where it idles at...and it works now..
thanks alot though
iroc2nv
Old Dec 29, 2002 | 02:43 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
thanks alot though
iroc2nv
I suggest you verify it with a separate tach just in case
Daz
Old Dec 29, 2002 | 02:45 PM
iroc2nv's Avatar
Axle/Gears: 3.45
yeah i will...im not driving it anytime soon and when i do it will have my autometer pahntom gauge on it as well..
but thanks for everything
iroc2nv
69GTOby
Apr 18, 2016 02:34 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Nighthawkf-117
Sep 24, 2015 02:47 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
