Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Electrical Question
Old Jan 13, 2003 | 11:57 AM
IROCKER's Avatar
Electrical Question
How would I wire something into the fuse panel? Rather than splice off an existing wire, I would rather give it it's own fuse, just to make it a little cleaner. But I have no idea how it's done.
Old Jan 13, 2003 | 04:14 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Most fuse blocks come with spare slots for additional fusing.
Just make a jumper from a 12V battery source in your fuse block to one side of a spare spot for a new fused circuit within the fuse box. And from the other end of the fuse, run it to wherever your going.
Don't forget to calculate a proper fuse size.
Old Jan 14, 2003 | 07:44 AM
IROCKER's Avatar
Pardon my lack of electrical knowledge here as I'm sure this sounds pretty stupid, but what would I use as a jumper? If I were to look at the back of the fuse block (which I haven't done yet) would this be obvious to me? And it's for the power seats, so whatta think, 30A or less?
Old Jan 14, 2003 | 12:26 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
Just do what I did. Plug all the wires into the elec utilities fuse... I have like 3 wires in there haha
Old Jan 14, 2003 | 01:25 PM
IROCKER's Avatar
*shakes head*
Old Jan 14, 2003 | 02:34 PM
Paul_Hughes_87 T/A's Avatar
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
Chris the wire in the fuse is a old stereo installer trick and it works real well. If done right you do not see it at all. BUT I would never put more than 2 wires in that way.
Old Jan 14, 2003 | 02:37 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I have done that in the past for sterio's and power seats etc, Like Paul mentioned etc, it works fine etc and its easy to do...if you are really concerned about it etc you can always wire in an inline fuse....Also, i would not suggest patching in multiple wires that way.
Old Jan 14, 2003 | 02:40 PM
IROCKER's Avatar
I did want to wire it in properly though. I know I'm making it harder for myself perhaps, but I just want it done clean.
Old Jan 14, 2003 | 03:59 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
There should be blank fuse spots on the block. One side of the blank should be marked "Batt". Measure if you have 12-14V there. If so, good. If not, then find a 12V side from another "existing" fuse and using a small piece of wire with a spade connector on each end. Put one end of the wire in with the existing fuse on the 12v side, and the other end of the wire with the spade connector into one side of your new "blank" fuse holder spot. From the other side of the blank, use another spade connector to plug into the fuse spot and then staright wire out to your power seats. I'm not sure how much you weigh so fuse size may be different. Start with a 15A and sit in the chair and see if you can use it rregularely with it. If the fuse blows, keep going up a size till you find one that will not blow under normal operation.
Remember: the wire you use has to be large enough to handle the current you draw. In other words don't use an 18guage wire and fuse it with 30A. You'll melt the wire before the fuse trips.
Here's an idea on wire size:
15A use number 12AWG wire
20A use number 10awg wire
30A use number 8 AWG wire.
I would find yourself some number 10 and use that. You should be safe even if you have to fuse it at 30A.
Good Luck.
Old Jan 14, 2003 | 04:47 PM
whudya mean everythin is clean, i just covered the wires all up with some black ducktape! (YES COPPER CHIP, ER.. HCICK, DUCKTAPE!)
Old Jan 14, 2003 | 05:46 PM
Slashmeiser's Avatar
Go to Canadian Tire. I'm not sure what its called but you can buy a device which takes the place of one of the fuses. And you can put 2 fuses in it. I'm sure if you look in the auto section you will find it. Has a wire coming off it for hook up, and then just find yourself a good ground. Screw it into a part of the body but take some sandpaper to take the paint off so you get a good ground.
Old Jan 15, 2003 | 05:40 AM
IROCKER's Avatar
Cruz and Slash: Thanks.
Easy: *shakes head*
Old Jan 15, 2003 | 11:20 AM
Car: Chrysler 300c
Engine: 5.7L Hemi
Axle/Gears: 2.89
Easy: *shakes head*
What about Paul?
Old Jan 16, 2003 | 07:02 AM
IROCKER's Avatar
haha...joking dude.
MustangBeater20
Oct 29, 2022 09:20 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
