Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
V6 to V8 swap
Old Jan 13, 2003 | 06:28 PM
Slashmeiser's Avatar
V6 to V8 swap
Anyone have any ideas how hard it would be to swap a v6 for a v8. The v8 is a 305. Thinking about doing it but not sure where to start or if it would be more trouble then its worth.
Old Jan 13, 2003 | 07:51 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
what kind of V8 or V6? Its not hard its just a matter of gathering parts..Biggest work would be drilling holes for the tranny crossmember if its even needed.
Old Jan 13, 2003 | 07:54 PM
i believe its a 2.8 litre v6 and the v8 is a 305
Old Jan 13, 2003 | 09:11 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Swap
It's a piece of cake, just finished doing just that. No holes to drill they are already there. Unbolt old, install new, plug in wires and go! I did an '87 Firebird and had a donor car, (also '87) made rounding up parts alot easier. You will have to move some brake lines to make room for the larger motor mounts (V-6's are in the front of the crossmember V-8's go on the rear of it). I also got a V-8 guage cluster so the tach would be right. The throttle and cruise control cables need changing too. The V-6 ones look like they would work but the mounting to the pivot is off by 1",so no go.
Good Luck.....
P.S. Forgot, you do need the V-8 trans (bolt pattern is different) crossmember and driveshaft all mount up.
Old Jan 13, 2003 | 09:16 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
I've done one. Its not too bad as long as you have all the parts. If its a fuel injected V6 to carb V8 swap, your biggest problem will be the fuel pump. The EFI V6 one has to high a psi rating for a carb so you will either need to replace the intank pump for a mechanical or carb safe electronic pump, or get a pressure regulator to lower the psi to around 6psi. Replacing the pump with a correct carb one is the best way to go. If you do get a regulator, make sure to get a 3 line reg, that has a return line to the fuel tank. The cheaper 2 line reg will work, but it will probably wear out alot quicker.
I think the motor mounts also need to be swapped out, which can be alot of work as well.
Old Jan 13, 2003 | 10:15 PM
icebird_1981's Avatar
u need to replace the gauges when u do a v6 to v8 swap why??
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
