Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
how do i find out what cam i have?
Old Jul 1, 2003 | 04:54 PM
icebird_1981's Avatar
the cam in my motor was swapped my mechanic is telling because of this it will not idle perfect. how do i find out what cam i have in my car?
Old Jul 1, 2003 | 05:35 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
Unfortunatly, there is no easy way, unless you have a dial indicator gauge. You would have to take the valve cover off and setup the gauge so it would measure the lift of the cam. You could probably take the measurement off the pushrod and then multiply it by 1.5 to get total valve lift. You wouldn't be able to calculate the duration of the cam this way, but with the lift total, you should be able to at least get a ballpark figure for it. You could pull the cam out to see if there are any part number stampings on it, but if you plan to do that, probably alot easier to buy a new cam to throw in, and being sure of what it is, rather than go by a 'guesstimate'
How does the car idle? It could be there is a vacuum leak somewhere which is causing the poor idle and not the cam.
Old Jul 1, 2003 | 06:53 PM
it does not idle really bad it just a bit more shakey then i am use to. but ya it is just what my mechanic said i have a high lift cam and thats what makeing it a bit shakey. the vacumes and everything is all hooked up and no leaks just had them replaced.
Old Jul 1, 2003 | 08:25 PM
(BR)G-Machine's Avatar
What rpm does it need to idle? Are you able to use your power breaks?
gta90
Sep 15, 2015 04:00 PM
Reborn756
Sep 4, 2015 03:42 AM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
