Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Headers bolts
Old Jul 3, 2003 | 10:02 PM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Headers bolts
Hey guys
I have discovered that I have a header leak coming from the passenger side. The header bolts appear to be loose and I can't get to them because of the air conditioning box and pollution pump.
Does anyone have any suggestions on how to or what tools are needed to tighten these annoying bolts?
Thanks for your help in advance.
Benny
Old Jul 3, 2003 | 10:25 PM
Corbi_85-IROC's Avatar
Car: 85 iroc z
Engine: LG4 :(
Alot of patience and maybe some shortening of existing wrenches. Not really any help, so sorry.
I have heard on this message board I think, of a guy swapping out the header bolts with bolts that use allen keys. I want to try that one, but my engine bay is a lot more empty than yours so its not that big a deal for me.
Old Jul 4, 2003 | 12:06 AM
Kevs87TA's Avatar
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Have you tried getting at them from under the car. It is a tight fit, but if you can get a wrench on it, you should be able to tighten them up. It would probably help if you have someone above to guide you. Worked for me...then again, I have a carbed engine.
Old Jul 8, 2003 | 06:07 PM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
I cut about an inch off of the wrench I use for them and keep it with me in the car. I check every time I check the oil and other under stuff.
Just get a crappy tire wrench and chop it down with a hack saw.
tj
Old Jul 10, 2003 | 09:52 AM
Steve89GTA's Avatar
Benny, forgot to ask but do you have lock washers installed on the bolts?
Here's a set out of Jegs from Mr. Gasket. A buddy of mine has these on his trans am and they work great..
http://www.jegs.com/cgi-bin/ncommerc...53&prmenbr=361
Old Jul 10, 2003 | 09:53 AM
Steve89GTA's Avatar
Here's the link to the stage 8 locking bolts. These will solve your problem for sure..
http://www.jegs.com/cgi-bin/ncommerc...79&prmenbr=361
Old Jul 11, 2003 | 07:37 AM
dcz28's Avatar
Car: 91 Z28 S\Charged
Engine: 5.7 L 350 CI
[QUOTE]Originally posted by Steve89GTA
[B]Here's the link to the stage 8 locking bolts. These will solve your problem for sure..
[url]http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?pJuly,11th 2003
Those WILL DEFINITELY solve your problem, i have them on my car. they are sooooooooo good to go!!!!!!!
Old Jul 11, 2003 | 08:45 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I've had that setup for a while. Stainless Allen key bolts and some 3/8 lockwashers, and your done.
Old Jul 11, 2003 | 09:46 PM
Engine: 305 cid
Hey guys,
Thank you all for you recomendations. It makes good sense to change the bolts in order to avoid getting my hands scratched and cut everytime I try tightening them.
I don't necessarily have to buy them in the states, I can get these bolts through Karrbelt right?
Benny
tom1985
Apr 19, 2016 07:55 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
