Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
the gremlins are back!
Old Jul 6, 2003 | 04:51 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
driving today... park the car....
go back to turn it on 30 minutes later and when i turn the key in the ignition, it makes that sound as though the car is already on and you're trying to turn the ignition... you know... that loud annoying sound.... KCCHH!
anyhow, later today... driving home and my car stalls at the stop sign.
i try to turn it on... it's chuggin' but it won't start..... i pop the hood look everything seems to be normal... only thing is my car was running a little hot...
i go to turn it on, it's chuggin chuggin chuggin and it finally starts but i see the rpms going down so i freaken gun it like crazy and speed all the way home running through the stopsigns....
it seemed as though it was running fine once the engine temperature dropped....
Old Jul 7, 2003 | 07:54 AM
Steve89GTA's Avatar
You may have some grinded teeth either on your starter or flywheel. Once you get that 'grinding' sound, you will get it again...if the the starter happens to contact the affected area during startup.
Old Jul 7, 2003 | 07:58 AM
eggcelent
first gear?
Diablo3Z28's Avatar
Car: 1986 Camaro Z28
Engine: Built Vortec 350
Transmission: 700 R4
I had that grinding sound on my buick when I tried to start it up. And after running the car for awhile and shut off and try to restart it was a chugging sound. I ended up having to wait like 10 mins before it would start. Turned out to be my starter. There was a piece (can't remember exactly which one) that was dying. After replacing the starter though it was fine
Old Jul 7, 2003 | 08:05 AM
Steve89GTA's Avatar
If the starter solenoid is old, it will be prone to heak soak (especially on hot days) from the engine. If you wait a bit and it starts fine, change your starter motor.
Easy, it's pretty easy to do. I did mine in my garage. Buy the new one, swap, and bring the old one back. DO NOT OVERTIGHTEN the electrical connections on the solenoid - or you will crack it!
oh, and disconnect the battery completely. The power (red) wire goes from the battery to your starter.
Steve
Old Jul 7, 2003 | 08:09 AM
how much does a starter cost?
i already told myself that if it's the fuel pump i am putting the car away for winter storage... lol
Old Jul 7, 2003 | 08:12 AM
Steve89GTA's Avatar
You can get one from crappy tire for around 200. When you bring the old one back, they give you $50 or so for it. (can't really remember now, it's been like 3 years since I'v changed mine).
Do you want me to price one for you from my supplier? I basically pay what mechanic shops pay for parts...
Old Jul 7, 2003 | 08:22 AM
hah tell ya what, i'll live with my car for now and if it dies i'll let you know, but thanks.
Old Jul 7, 2003 | 08:26 AM
Steve89GTA's Avatar
lol. At least your car is stick so you can roll start it WHEN it leaves you stranded...
Old Jul 7, 2003 | 09:52 AM
HOW DO YOU ROLL START BTW?
lol
some guy stopped me the other day told me his starter was gone and told me to push his car
i pushed and he started it, i was like wtf?
Old Jul 7, 2003 | 09:59 AM
Steve89GTA's Avatar
Turn the key to the ON position, roll the car, push clutch, put gear in 1st or 2nd and let the clutch out - don't 'pop' it but let it out quite smooth and quick. Car should start right up. If id doesn't, you need someone to push harder/faster. Once it's running, don't stall it - if you do - repeat above.
Old Jul 7, 2003 | 10:07 AM
cool
Old Jul 7, 2003 | 10:15 AM
Corbi_85-IROC's Avatar
Car: 85 iroc z
Engine: LG4 :(
Transmission: 5 speed
Maybe you should practice it a couple of times on an incline somewhere, so that if you should ever have to do it you'll know for sure how. Nothing worse than being frustrated that your car won't start, and trying it for the very first time.
Old Jul 7, 2003 | 05:03 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
i have
I have starters!!..I just rebuilt one for the IROC but never get to use it..lol
Daz
Old Jul 7, 2003 | 09:25 PM
i actually doubt it's the starter
mainly because why would my car stall if the start died?
Old Jul 7, 2003 | 10:02 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
could be a loose connection in the solenoid or even a failing connector in the solenoid or short
Daz
Old Jul 7, 2003 | 11:15 PM
Steve89GTA's Avatar
I agree. The problem definitely rests with the starter. Check the connectors. You'll need to jack up the car on the front passenger side and crawl under there (toward the rear of the block on the passenger side.)
Old Jul 8, 2003 | 01:22 AM
BUT UH...
doesn't the starter only start the car?
my car stalled while it was driving....
Old Jul 8, 2003 | 07:28 AM
Steve89GTA's Avatar
Your primary positive wires from the battery go directly to (drumroll please) your starter.
But uh
Old Jul 8, 2003 | 08:22 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Maybe someone popped the clutch...
Old Jul 9, 2003 | 05:31 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
BUT UH...
when it dies do you have ANY power at all ?
Old Jul 9, 2003 | 07:03 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
or the alternator again..lol
Daz
Old Jul 9, 2003 | 11:37 AM
actually i believe the problem to be the car overheating...
i'm guessing the computer automatically shuts it off and won't let it start again until the engine temperature goes down.
i am letting the car sit in my garage until i figure out how to wire up a switch for the fan
Old Jul 9, 2003 | 11:45 AM
Steve89GTA's Avatar
Why did your car overheat. Do you have the original waterpump and thermo in their?
After having nightmare after nightmare with this (when I first got the car), I did the timing chain, waterpump, Jet 160 fan switch, 160 thermostat, new rad/hoses and haven't had a problem since. Car stays right in the center of the temp guage and that's the hottest it'll get...even when it's 40 degrees outside and I'm driving like a fool...
Old Jul 9, 2003 | 11:50 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Axle/Gears: Posi/3:42
Alex,
You may want to get your fuel pump checked. A faulty fuel pump can be the culprit. When the pump gets hot it just dies and no fuel gets to the fuel rail; and therefore, the car stalls.
Worth the check.
Old Jul 9, 2003 | 11:53 AM
Steve89GTA's Avatar
Benny, you going to Applewood tonight?
Old Jul 9, 2003 | 12:02 PM
Engine: 305 cid
Hi Steve!
Yes I'll be there tonight.
How about you?
Old Jul 9, 2003 | 12:04 PM
Steve89GTA's Avatar
Yep,
Directions wise. Do I get off the QEW at Dixie and then follow the signs to North Service Rd? Haven't been down there in a little while...
Old Jul 9, 2003 | 12:30 PM
Engine: 305 cid
You would get off at Dixie and just follow to North Service Rd. You will see the mall on your right hand side.
Fronzizzle
Mar 18, 2019 08:29 PM
db057
Aug 22, 2015 08:17 PM
86IROC112
Aug 21, 2015 07:20 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
