Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
power stearing bracket's???
Old Aug 7, 2003 | 03:59 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
help, I need close up pic's of the way the power stearing brackets go on. I have a 355ci with l98 heads, flow tech hedders, and I removed the A/C. and can't for the life of my figure out how they go on. please help. thanx
Old Aug 7, 2003 | 04:14 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
The power stearing uses some of the brackets from the A/C system to bolt to, as well as the first bolt in the driver side header. Its pretty easy to work around this however. Best thing to do is to replace the first header bolt with a long stud, then use a couple of nuts on either side of the power steering bracket to hold it in place. I've done it this way, and i've also not bothered to secure the bracket to the header bolt. You can run it without the stud, but the power steering assembly will have some flex and might loosen up over time (it did this to me).
Going by memory, the top of the power steering pump bracket will bolt to the head. You might need to space it using washers or whatever. The 1/4 circle looking bracket should have a bolt hole on one end and a slot on the other end. The bolt hole bolts to the engine block and there should be a stud (or bolt) on the power steering bracket that will go through the slot on the 1/4 circle looking bracket. The 1/4 circle bracket is the one that can be secured with the stud in the first header bolt hole.
Hope this helps
Old Aug 7, 2003 | 09:46 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
HA! I hear ya. The power steering brackets were a biatch trying to figure back on when i dropped my L98 in the Roc. Unfortunately, at this point in time I don't have any pictures displaying how to replace, but Kevin V is accurate in his description.
Old Aug 12, 2003 | 11:47 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
I don't have TPI i'm running a carb and non-surptine belts.and any with a close up pic would be nice.
Old Aug 13, 2003 | 08:04 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
ok when i go out i will snap a pic for you.....
Squeaky8791
Feb 5, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
