Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
It's Time
Old Aug 14, 2003 | 06:10 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
It's Time
I've posted here before about a 327 TPI. Well I finally received my chip and I now have all the parts needed to do the swap. No more bull****ting or "When you gonna swap engines?" I'm gonna do the swap this weekend. This is what I have
1992 Camaro RS
25th Anniversary Heritage Edition
Red with Black
Stock TH700R4 Transmission
2400 Corvette Stall Converter
Stock Suspension
15" wheels, 225 tires front, 245 tires rear
1968 327 2 bolt main block
10:1 compression
bored .030 over (that puts it at 331 c.i.d)
ground .010 on the mains
TRW hypereutectic pistons
hi- perf seals, moly rings, bearings, rods, rod bolts,
frost plugs, ect.
ARP bolts through out
double roller timing set with thrust button
hi-perf oil pump and drive
baffled oil pan
291 casting heads
64 cc chambers
1.94/1.6 valves (3 angle grind)
1.52 roller rockers
pushrods, guideplates, screw in studs, guides, ect.
polished and ported
camshaft 220/231@.050, 468/480 lift, 110 lsa
1991 Speed Density TPI
Ported, Polished, Siamesed Plenum and Intake
Stock Runners
48mm Throttle Body
19# Injectors
Adjustable Fuel Pressure Reg
350 Knock Sensor
170* stat
Heddman 1 5/8" Longtube Headers with 3" collector
No cat
3" exhaust
the EGR deleted,
the temp at which the fan comes on lowered,
the VATS disabled (going from TBI to TPI, might be a problem ),
the RPM for the VSS extended as I want to rev
I will be busy this weekend !!!! HAHA!!!
Old Aug 14, 2003 | 09:35 PM
johnyIROC's Avatar
Good luck bro!
Old Aug 15, 2003 | 09:06 AM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
:hail:
Old Aug 15, 2003 | 09:19 AM
(BR)G-Machine's Avatar
If the 291 heads are what I think they are... you will have to grind you middle 4 intake bolts... but you probably know that.
Old Aug 16, 2003 | 07:44 PM
Stroked-Z's Avatar
I was just about to post that, the 4 center intake bolt holes will have to be elongated.
Good Luck & let us know how it goes.
Old Aug 18, 2003 | 08:49 PM
I worked on it all weekend, only had 6 hours sleep, the best I could get was it to turn over and backfire occasionally. The timing seems to be messed up. I can't get it to start. Also the ground for the battery gets real hot, something not right. I think I'm gonna take her to a shop. Don't care how much it costs right now, I need it to run........ ....... .........
Old Aug 18, 2003 | 10:28 PM
Stroked-Z's Avatar
RattleSnake,
Make sure you have a good ground going from the Body to the battery, and a good ground going from the block to the frame. The battery to body should be 12ga, and the block to frame should be at least a 10ga wire.
When you dropped the distributor back in, did you set the motor at TDC and give yourself a new mark for the #1 Position on the distributor cap?
Old Aug 18, 2003 | 10:45 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I hope youre chip works for you..That separation is waaaaay too much for a stock SD and the duration is kinda opposite of what the stock induction likes..Well its all theory until it gets tried out..Good luck
Daz
Old Aug 22, 2003 | 09:10 PM
I did her. I got her to run. Took me a whole week. This has been a very frustrating experience.Swapping out the TBI 305, swapping in the 327 TPI, installing the long tube headers, installing the TPI wiring harness ( Firebird harness in a Camaro..not for the faint hearted), getting it to run....... need sleep..... but I got the 327 TPI to idle in park at 750 rpms. Let me tell you, it sounds mean running off the long tubes. Very strong, I'm pleased. Now to get it out on the road and break her in. I had mega timing problems, the custom prom didn't work worth a fart....... I'm running it off of the 305 chip and 19lb. injectors. Gonna go see about larger injectors tomorrow and see if I can get it to run with the custom prom, before I send it back. 327 TPI !!!!!
Old Aug 24, 2003 | 09:49 PM
Fixed all the problems, got all the bugs out. Fired her up, timed her in, no leaks. Pulled her up to 2000-2200 rpm and held her there for 15-20 mins, no leaks or anything......so I drove her around Oakbank for 10-15 mins tonight. Sounds real mean.This car kicks ***, the chip seems to be doing fine with that cam in it. But yeah I do have low vaccum. Other than that it's killer. I got to get a starter heat shield and maybe some exhaust pipe to put behind those headers, gotta keep the noise down a bit HAHA !!!! I would like to thank Perry's Machine Shop for building the bottom end and head work, Ideal Direct Parts for the TPI unit and wiring, Pcm for less (pcmforless.com) for the killer chip work, my Bro, Sean, for the endless long hours of frustrating work he put in, Mom and Germain for there support. Sounds like some sorta awards speech...... going to sleep now, what a week..........
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
