Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
View Poll Results: What would you like the lap timer to be?
Alluminum (fake)
0%
Carbon fibre (fake)
0%
Gloss black
0%
Flat black
100.00%
Voters: 2. You may not vote on this poll
Tap Timer (2)- Emergency question!
Old Mar 27, 2004 | 12:55 PM
(BR)G-Machine's Avatar
Hey guys... need your take on what you thing you, and the average racer would like to put into the interior of your racer or street machine.
Just as a refresher: the Lap Timer is a piece of electronics, that would (using Gps technology) time how long it takes to return to a set point: the starting line. What I am doing is having a button module that will strap to the steering wheel, and a display screen (about 15 cm x 10 cm) or an optional heads up display that would project on to your widshield. It would display current lap time, current total time, past lap times, and average lap times, and on another menu exact speed, and acceleration.
Okay what I need to know is what sort of material you would like to see it as. Basically, it has to be plastic... just the nature of manufacturing right now... but it can be textured and colored to mimic certain materials... like alluminum. The choices I have thought of-
1) Gloss black
2) Alluminum (semi gloss aluminum grey)
3) Some sort of carbon fibre veneir or surface.
Of a combination of course.
What do you guys like? More suggestions?
Old Mar 27, 2004 | 04:41 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I vote for satin black. That way it will match the cheapo plastics in thirdgens and it's also an easy finish to apply.
Old Mar 27, 2004 | 08:47 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
some kind of dark black non-glossy finish - if it matches the high quality cheapo plastique in a thirdgen that would be OK to - just so long as it works better than taping stop whatches to the steering wheel.
Old Mar 29, 2004 | 04:31 PM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
flat black sounds perfect for our cars and won't show scratches from getting shoved in the console
Vintageracer
Jan 10, 2020 05:33 PM
Cameeeero
Sep 18, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
redmaroz
Aug 16, 2015 11:40 PM
