Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Motor mount questions...
Old May 8, 2004 | 03:54 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Fired the monster up today, and saw that I definately need motor mounts. The motor dances back and forth in the current rubbers and my exhaust collect hits the frame because of it.
Question is will stock replacement rubbers dance as bad, how much play do they allow? I'd get poly or urethane mounts but I want a smoother ride.
Suggestions, comments?
Old May 9, 2004 | 03:24 AM
Stroked-Z's Avatar
You can get a replacement "HI-PERF" motormount from Carquest, i used those for a year....
I switched to a polyurathane mount after, much better control of the motor.....
Then im at solids now, you feel everything!
Old May 9, 2004 | 08:46 AM
mikesz1984's Avatar
Car: 1984 z28
i just put a set of stock mounts back in my car, i dont race the car much or even beat on it a lot, most of the people i hear from want the poly mounts though, they last longer and give better support for the motor. the choice is yours. but if you are changing them yourself have fun
Old May 9, 2004 | 10:14 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I've read a few times that the poly mounts raise the motor about half an inch or so which may or may not be a problem.
Old May 10, 2004 | 07:53 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
a 1/4" raise would not allow me to close the hood.
I picked up a set of rubber mounts today. They'll do for a season or so, I won't be kickin the crap out of it all the time anyways.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
