Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
car overheating
Old Jun 17, 2004 | 05:04 PM
curtis84ta's Avatar
Car: 1984 pontiac trans am
Engine: Block #14010209...350...80-85
Transmission: 700 R4
car overheating
im having probs with the car overheating a lil bit it jumps to the line after 105 but doesn't go anyfurther, anyone know what might be wrong? is it the thermostat sticking or is it something else? and yes i do have oil in it and coolant.
Old Jun 18, 2004 | 01:07 AM
Pacer's Avatar
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
Try replacing the thermostat after you clean out between the radiator and condenser ... you may have leaves stuck in there (I did).
Sometimes thermostats start to "go" with age. Replace that first. Should take 45minutes and cost $15 or so. Don't forget to buy the gasket.
You may want to check your coolant/water mixture too, or do a complete flush if you haven't in a few years ... good for the radiator. Old antifreeze becomes acidic after many years, deteriorates the radiator and decreases cooling ability.
Let us know what happens.
Pacer
Old Jun 18, 2004 | 09:20 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Ya, I'd start by flushing the whole system out, engine, heatercore, radiator. I usually just take the hoses off and shove a hose in the end and flush until clean water comes out. I'd flush, then drain the engine as well, there are little plugs unger the exhaust manifolds to get the water out before you add cooland mixture again.
Look in the manual and see what the total capacity of the system is (volume wise) as you won't be able to get all the water back out of everything after flushing.
To re-fill, add 50% of the total volume in new 100% glycol, then top up with water to get the proper 50%/50% mixture. I use the
Is your rad rotten, ie the little fins falling out/apart?
Shoot a 160 or 180 stat in it.
Old Jun 18, 2004 | 02:07 PM
Pacer's Avatar
Transmission: 200C
Ya, a 160 stat may do the trick. I run on a 160 in my LG4.
But try the above steps first.
You may have also had an air lock too ... flushing properly will hopefully rid of this problem.
Pacer
Old Jun 18, 2004 | 02:24 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I had problems with mine years ago. There was a lot of dust and dirt and crap that had got between the vanes in the rad. Blew it all out with an air hose and no more problems. I had the schroud off a few weeks and I noticed that the dirt had started to accumulate again. Might be worth checking that.
Old Jun 19, 2004 | 01:31 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
haha you're worried at your temperature going to 105... mine goes to 120... been like that for 2 years...
i've changed everything and anything already and it still goes that high.
Old Jun 19, 2004 | 11:43 PM
curtis84ta's Avatar
overheating
well i put in a new thermostat and flushed the system thoroughly, my rad was already clean no dirt or dust in it, like 2 leaves. drove it for about 20 mins and it stayed under 80 degrees the whole time, i tried pushing it a lil bit and didn't go anywhere so it was the thermostat and it was a lil sticky.
thanks for your help
Reddeath210
Oct 6, 2015 08:20 AM
mustangman65_79
Sep 1, 2015 03:51 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
