Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
AIR setup and e-tests
Old Jul 10, 2004 | 10:22 AM
Kevin Vandevenne's Avatar
Car: 87 IROC
I was thinking down the road if i ever put headers and an exhaust setup on my car, I may convert it to a single cat setup over the dual cats, for the main reason there isn't as many options available with the dual cat setup.
If I yank the AIR setup at the same time, I'll fail the visual part of the e-test correct? If by magic a 406 happens to get swapped in a day before the etest, I could pass as a hot rod as the visual inspection only checks the gas cap for hot rods, correct?
Old Jul 10, 2004 | 12:23 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
I'd go to a single cat system - seems to be too much BS with the dual setup for what it's worth.
As for the emissions there were some posts a while back which went into all that in detail - I think the better ones were on ccfbg.com - one of the respondents had taken the minsitry certification course for all that schit so there was a lot information.
Old Jul 10, 2004 | 05:16 PM
darbleinad's Avatar
Car: 84 Trans Am
as for the AIR system itself, there is only a very small chance that it not being there it will cause you to fail the actual exhaust emissions test, but as you say, the visual inspection is where problems arise.
i think you should remove all the air stuff and then tell them you swapped in a 400 small block. chances are very, very slim they would actually look up the block casting number. go to an indepent shop where you can talk to someone and make a deal.
Old Jul 10, 2004 | 05:44 PM
mikesz1984's Avatar
Car: 1984 z28
yes you could rip it off, but if you get stopped in a roadside check that would be a 380 dollar fine, they also could pull your liscence plates untill it passes another e-test. A bunch of people are going through this right now in kitchener waterloo. (under the hot rod classification you dont need this stuff to pass an e test, at the roadside inspections you do, they dont care what you have only what the car came with)
Old Jul 10, 2004 | 10:10 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
My car came with headers that had the air tube holes welded shut. The tubes for the manifolds are gone and the rubber hoses are plugged. I also had a 1/2" hole in my cat where an airtube was supposed to be hooked up. I passed the visual inspection and it passed the e-test very well.
I think its just a matter of where you take it.
Old Jul 11, 2004 | 07:44 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
Exactly. I'm not friends with the place I take my car too and the guys there said they dont care what a car has for equipment as long as it passes.
Old Jul 12, 2004 | 11:34 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Kevin,
You are right about the hotrod and visuals. I passed the Hotrod e-test with the Lt1. I ONLY have the gas cap.
I also have the pages from the e-test manuals as backup.
Hotrod=different engine displacement block than what was originally offered in THAT year of production (boring,stroking aside). They didn't seem to care my 350 is a genII block etc, only that it was a 350 in an 86.
Terrell351
Jun 13, 2021 01:13 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
krisner89
Oct 10, 2015 06:03 AM
Street Lethal
Aug 13, 2015 08:28 PM
