Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Breaking the cam in, headers started glowing
Old Aug 5, 2004 | 07:29 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Never seen this before the motor was running for a few minutes at 2000rpm, timing seemed advanced enough, pulled a plug, it was white. I don't know...
Old Aug 5, 2004 | 08:13 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Sounds like your running way to lean. I know you have a 383, but what cfm are you running, and your compression ratio also???
Old Aug 5, 2004 | 11:03 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
too much advance can cause that too..
Daz
Old Aug 6, 2004 | 08:07 AM
screamin'chickn's Avatar
Car: 86 T/A
Engine: 327
White plugs = lean
Retarded timing and crappy fuel can make the situation worse on a run-in.
Old Aug 6, 2004 | 05:24 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
rejetted the carb from 67/73 to 73/76 and the plugs are starting to brown up, and no header glow. Because of the crazy temperatures, I never got to "really" break the cam in for a full 15-20 mins. More like 5 min spurts. but I'll try again, it hasn't been under load yet, so I think I'm OK.
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
drathaar907
Aug 6, 2015 04:20 PM
