Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Coolign question....fan not comming on?
Old Aug 8, 2004 | 03:09 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Question for you guys. Earlier today I decided to toss my smog pump and all the AIR lines back on the car and make them functional again since I hear the "smog police" are making their rounds again (shouldnt have touched them in the first place)
Everything went on as i would expect....BUT....the car is running hot and the fan isnt comming on....Coincidence????? It was fine before doing the work earlier today...any suggestions on what to check out????
Thanks,
Dave
Old Aug 8, 2004 | 04:29 PM
iroc2nv's Avatar
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
dave,
there is a little black "BOX" (like a fusiable link) that is almost right beside the battery on the pass side (almost near the headlights on the inside of the motor compartment) youll see it..
when i took all my emission crap off my fan didnt work and it was cuz of that box.. i went to a few scrappers and couldnt find any...so..i just toggled the fan and now i can turn it on and off whenever i want...maybe you should do something like that...save you time and effort in the long run..
hope this helps
iroc2nv
Old Aug 8, 2004 | 05:01 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Try grounding the coolant temp. switch wire and see if the fan comes on. Then you'll know if it's the switch or the relay. Odds are the fans are fine.
Old Aug 8, 2004 | 07:13 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
dont ask me how/why...but its fine now, must have been a connection which got bumped...even though I checked all of them when I first tried to fix this problem.........sometimes things just "happen"....lol....regarldess its all good now..thanks for the suggestions guys.
Dave
Old Aug 8, 2004 | 08:13 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Same thing happened to me. Everything was working. Pull the motor, put it back in, now my coolant temp. switch is shot.
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
BADNBLK
Nov 16, 2016 09:12 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
