Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
sleep time!
Old Sep 22, 2004 | 03:52 PM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
sleep time!
SUP everyone. well the time of year is here and im putting the camaro away for the winter. im parking it in a underground storage and driveing my new 04 lancer for winter. i was just wondering if there is any dos or donts? should i start it up from time to time and let it run? should i keep it off all winter? should i keep a fulll tank of gas in it? ect.....
so fare i cleaned it all out, took out my system, put $hit tires and rims on that i dont need. and i am going to take out the battery, is there anthing else i missed?
Old Sep 22, 2004 | 05:33 PM
DoBeR's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Transmission: 4 Spd Auto
Make sure you top up all the fluids including the gas tank as you mentioned because if its empty, moisture can get inside and start rusting. Also get some gas stabilizer because it will go bad after sitting over the winter.
When I put mine away for the winter, I dont start it at all. I figure one dry start after the winter isnt as bad as starting it once a month.
I didnt even remove my battery, I just unhooked it, and hooked it back up 6 months later in april and it fired right up no problem.
I covered up my tailpipes so nothing would go inside there and also put a small dish of baking soda on the floor to help with moisture. It seemed to work fairly well. I also put some bounce sheets in different areas because its supposed to keep mice away.
Old Sep 24, 2004 | 09:27 PM
Pacer's Avatar
Car: 82 Camaro Pace Car & 1989 IROC
Engine: LG4. & 350 TPI
Transmission: 200C
Is it my imagination ... or isn't it a bit early to store cars right now?
Old Sep 24, 2004 | 11:21 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
It's your imagination Ron - it's been damn cold this last couple of days.
Old Oct 4, 2004 | 08:59 AM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
When you start it up for the first time, pull the coil wire and let it turn over for a while so that the oil pump can lubricate the internals. Then re-install wire and fire it up.
tj
Old Oct 4, 2004 | 11:49 PM
Pacer's Avatar
Transmission: 200C
George, you sleeping in the car again?
Kiss and make-up with the wife
Old Oct 5, 2004 | 08:20 PM
zedder 1 9 9 0's Avatar
Car: 1990 Iroc Z Convertible
Engine: LB9
I took mine off of the road early this year, hopefully next year will be better
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
