Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Peel and Stick Crap
Old Jan 7, 2005 | 07:17 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Peel and Stick Crap
That white stripe under the headlight cover over to the signal light is a peel and stick velcro strip for a nose bra. Is there anything I can use to remove it w/out messing up the paint which is base and clearcoat.
Old Jan 7, 2005 | 09:44 PM
rusty rider's Avatar
Car: 86 IROC
Engine: 305 lg4
If you try to soak it with goo gone it should come right off with a bit of rubbing , but i dont know what effects it will have on the paint. I used it on my car to pull off a few stickers with no ill affect as of yet.
Old Jan 8, 2005 | 09:20 AM
johnyIROC's Avatar
I would try using some localized heat.... maybe even a hair dryer to melt the adhesive.
If that doesn't work, I've seen the pros on TV do it with a piece of fishing line... by holding the line tight between two hands and getting it under one edge of the velcro backing, you can make a sawing motion with the fishing line and cut through the adhesive. I've never actually tried this one but it seemed to work very well when they did it on TV.
Goo Gone might work to clean up any mess after it is off...
Old Jan 12, 2005 | 07:50 AM
Ratchet's Avatar
Use some vinyl stripe remover or decal remover comes in a spray can just spray it on and take it off. Does not hurt paint. Just ask the guys at any auto paint store and they should be able to hook you up.
The Stuff I got is made by 3M and is called woodgrain remover.
Ric
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
Drone358
Sep 28, 2015 04:55 PM
ndndndnd
Sep 28, 2015 08:00 AM
david068513
Sep 18, 2015 10:36 AM
