Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Anyone in the Ottawa lend a guy a hand?
Old May 23, 2005 | 10:59 PM
(BR)G-Machine's Avatar
I need some healp reassembling my Lg4. I am in way deep!
In the Spring/Summer of grade 12 I rebuilt the Carb, installed a Griffin Rad, B&M tranny cooler, EPS intake. Well I stupidly just left it partially rebuilt with the cab just bolted to the intake and went to University. Now it is 2 years later, and all I did was some body work when I was back home. And now that most, if not all the bodywork is done, I need it rolling.
Anyway, now I cant remember where the rotor was oriented, how to adjust the TV cable, which bolts went where... really stupid stuff. Stuff I am sure someone who is fairly competant with an LG4 or any carb motor could do without even thinking about it! Not to mention carb tuning, uhg.
I am just in way over my head! Any help would be soooooooo appreciated. Otherwise me and the manual will be spending alot of time together.
Old May 24, 2005 | 11:05 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Get TDC and point the rotor to the number plug wire/cap.Turn the crank until the timing mark on the crank is right before the 0 mark(cause of the advance).
Old May 24, 2005 | 11:59 AM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Where in Ottawa are you. I'm about 45mins south.
What type of carb?
Old May 24, 2005 | 06:19 PM
The car is in Manotick my folks garage, which is in the south end. And the carb is a Q-jet.
Old May 24, 2005 | 07:21 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
TV cable
Look for the metal button (its perpendicular to the bracket/usually semi-circular plastic housing)..lol I wish I have a picture..lol.. push the tab where the cable comes out in towards the driver while pushing the metal tab.Go inside the car and floor the gas pedal.You should hear the click as it adjusts itself.If it shifts too early then press the metal tab and loosen the cable.
Old May 25, 2005 | 07:45 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Make sure you get the TV cable right before driving the car too hard for too long. That cable controls the line pressures and shift points, its pretty east to fry a trans if its too loose. I almost did it in a few days.
Follow what Daz said, its pretty friggin easy.
Old May 25, 2005 | 03:50 PM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
I could probably swing out there some night and help you out.
Old May 25, 2005 | 04:48 PM
That would be awesome. Gonna tie up the loose end in the body work, and install some stuff I have been neglecting. Be a few day, anytime after I would totally appreciate the visit.
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
