New to the F-Bodies..
Car: 1991 Pontiac Trans Am
Engine: LB9 305 V8
Transmission: THM 700R4
Axle/Gears: 2.73 Limited Slip
Hi Everyone
As the title implies I have just obtained from my extended family a 1991 Pontiac Trans Am in need of some work.
I just want to introduce myself to this board.
Engine: LB9 305 V8
Well the work I know of it needs is at least one front fender (passenger) as well as passenger rear 1/4 panel. Possibly one floor pan.
Mechanically it has a possible flooding issue (low idle = stall), drivers headlight needs the gear fixed, and the hood sometimes refuses to release. Their suggestion to open the hood was to pop the hood, driver it for a few minutes and then open it.
I'll have more details after the weather gets better and I can take a good look at it.
Car: 84 Z28
Engine: Modded 350ci.
i had the same hood problem on my old 85 before i sold it.It took me pulling on the hood release while my dad or somebody would have to pull up on the hood to get it to pop.it was a rediculous procedure.
Hopefully you get all the problems sorted out
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
This board outta answer most of the issues that will come up with your new car! A bit of research here should show you what you can do with that base! Welcome btw!
Car: 1990 GTA
Engine: L98 5.7 L
Transmission: 700R
Axle/Gears: 3.45 9 Bolt
Welcome to the board. Good luck on your newly acquired ride. Any questions, just ask away or search the forums. More than likely, someone will have asked the same questions....lol
